Author: Subject: Mazda RX8 Drivetrain Package
yorkshire-engines
posted on 4/4/08 at 08:49 PM Reply With Quote
saw this advertised somewhere last week anyone know where it was
cheers malc
*1. Hi-Port RX8 Engine (231PS). Tiny and Light!
2. Six Speed RX8 Gearbox (yes - it will fit).
3. RX8 Limited Slip Diff.
4. RX8 Driveshafts.
5. RX8 Alternator.
All 2004 - 10,000 mies.
6. Brand New OEM Sump (Fitted).
7. Brand new Exedy Clutch (Not Fitted).
8. Brand New OBX Headers (Not Fitted).
Here's where it get's more interesting...
9. MAZSPORT <http://www.mazsport.net/> Kit (Brand New - Not Fitted) Comprising -
Microtech LT10S ECU
Ignition Solution Unit
Plug and Play Harness
APV Harness
Mechanical 70mm Throttle Body
Why is it for sale? Well, I can't afford to build both the V8 Ultima and the RX8 Caterham, so one must go... sorry Caterham!
All the eco-crap / comfort-aid electrics have been taken off the engine and it's pretty much a bare block, except for the necessary components.
The Oil Metering Pump has been removed, but it will come with the engine. Personally, I would keep it off and run the engine on Pre-Mix as recommended by Mazsport (there are NO aftermarket ECU's this side of £2.5K that can run the OMP effectively, and anyway - Pre-Mix is kinder to the engine).
The Mazsport kit was custom made at the factory for a Seven style application and the ECU / Ignition Unit mapped to run a bare engine. Together with a good exhaust (the OBX headers are equal length) the package should see over 250BHP.
Obviously, all the new parts are just that - brand new.
The engine, box, diff, shafts, and alternator are all in great mechanical condition and good cosmetic condition. Could all do with a wire brushing and a coat of JP1 Satin Black to make look perfect (and why wouldn't you want to?). I'd probably also re-seal the diff casing as the adhesive is looking a bit dry.
zilspeed
posted on 4/4/08 at 08:56 PM Reply With Quote
Username is Scootz in here.
