Author: Subject: Oooooh It runs better than ever
ditchlewis
posted on 5/4/08 at 11:07 AM Reply With Quote
I've removed the filterking pressure regulator from the wrong possition i had put it in and now it runs a lot better
it's still very over fuelled and needs the carbs setting up properly. But it runs
i'm just off for a 50 mile drive and we will see how it goes. wish me luck.
ditch
Stuart_B
posted on 5/4/08 at 11:16 AM Reply With Quote
good luck with the drive, all that extra fuel, you have to brun it.
stuart
edspurrier
posted on 5/4/08 at 12:13 PM Reply With Quote
Where's the wrong place for a filter king?
indykid
posted on 5/4/08 at 01:03 PM Reply With Quote
before the pump
tom
ditchlewis
posted on 6/4/08 at 09:25 PM Reply With Quote
Yes Yes Yes
the filterking should go between the pump and the carbs
the car ran better but it still had a minor misfire / stutter.
proberbly over fueled as the carbs have been played around with a bit.
it ran well and got well past the ton on the duel carriage way and it will out drag most things.
it's a bit tail happy though.
ditch
