RazMan
| posted on 7/4/08 at 08:13 PM |
Radio Muppetry
Messing about with the battery on my runabout Escort I now have a radio which refuses to switch on now, asking for a code
I haven't a clue what to do next - any ideas?
Raz
McLannahan
| posted on 7/4/08 at 08:15 PM |
Written in the original handbook Raz, normally on a small card?
If not known Ford will be able to give you the code - assuming it's the headunit fitted to the car when supplied new?!
If none of those...Get the code from it via a decoder radio type person! About £15 these days?
Paul TigerB6
| posted on 7/4/08 at 08:16 PM |
If you havent got the code written down then you could get in touch with the local Fraud dealer and ask them for it.
mistergrumpy
| posted on 7/4/08 at 08:22 PM |
On two Escorts I've had, well one mine and one from my then job the code's been written on the top of the head unit!
llionellis
| posted on 7/4/08 at 08:23 PM |
Had the same problem, took radio out and the previous owner had written the code on the radio case.
No idea why but saved me a load of bother.
matt_claydon
| posted on 7/4/08 at 08:33 PM |
I have a little program that will generate your code from the serial number for certain types of Ford radio ('M' series). U2U the serial
and I'll see what I can do.
Alternatively the code generators are freely available on the web and a google search should sort you out.
(The fact that such a generator is possible defeats the entire object of the code!)
RazMan
| posted on 7/4/08 at 09:07 PM |
Thanks for all the input guys.
I just looked inside the users manual and found a card with the code written on it - all sorted now!
Raz
jollygreengiant
| posted on 8/4/08 at 12:37 AM |
Go on then don't keep us in suspense what was the code.
PS only joking.
RazMan
| posted on 8/4/08 at 02:47 AM |
9999 - I suspect that it has been hacked
Raz
