mad4x4
posted on 16/4/08 at 05:44 AM |
Sump Guard
What do yo guys think -
Should I Weld the SUMP Guard to the MK INDY CHASSIS or BOLT it ??
Scot's do it better in Kilts.
Humbug
posted on 16/4/08 at 05:46 AM |
What do Yes and No mean here? Are you asking whether to weld or bolt, or whether to have a sump guard or not?
Danozeman
posted on 16/4/08 at 05:50 AM |
Id bolt it. Easy removable should u need it off. Plus when u bend it when u hit a speed hump you can change it.
Dan
speedyxjs
posted on 16/4/08 at 06:21 AM |
I voted yes and then read the thread
I vote bolt it on. If you then decide you want an engine change with a bigger sump, it will be much easier to change
Howlor
posted on 16/4/08 at 08:03 AM |
Bolt it for sure.
badding
posted on 16/4/08 at 08:24 AM |
I welded it togetjet and then bolted it to the chassis...![](/images//smilies/bigsmile.gif)
Humbug
posted on 16/4/08 at 09:25 AM |
I agree about not welding, but how about clamping it on (instead of bolting), to avoid having to drill holes in the lower rails?
posted on 16/4/08 at 09:41 AM |
I vote for PU.
mookaloid
posted on 16/4/08 at 12:28 PM |
I say bolt on and voted no - which I think is correct for this option
DarrenW
posted on 16/4/08 at 01:14 PM |
Is the question - should it be welded to chassis? Y or N.
Bolt.
Perhaps prevention is better than cure though. i stiffened front shox and raised front end a touch - car been better since.
Can you raise engine a touch?
