Stuart_B
posted on 17/4/08 at 02:01 PM |
Digtal dash
Hi all, has anybody used this
digtal dash for sva?
Is it any good?
anybody got pictures on where they fitted it and how?
and who does the sensor's work?
thanks
stuart
Mr Whippy
posted on 17/4/08 at 02:13 PM |
does it light up at night?
Hammerhead
posted on 17/4/08 at 02:39 PM |
only if the ignition is on
cossiebri
posted on 17/4/08 at 06:46 PM |
I've got one (as well as the indicator dash surround) But haven't fitted it yet well worth the money imo as it comes with everything
you need
If it doesn't fit MODIFY it!!
Cheers BriF
segan2b
posted on 17/4/08 at 06:55 PM |
Not a bad option IMO for a budget build. I have one fitted, it does everything it is supposed to do and is clear/easy to read.
The only problem I had initially was the rev counter reading, I had to add a diode and a capacitor between the coil and the unit to clean up the
signal as interference from the alternator caused some problems. Fine now however and would work well using the signal from EDIS or MegaSquirt.
I didn't have it fitted at SVA but as long as the Speed is calibrated correctly I cannot see any problems with the unit.
Sean
![](http://i163.photobucket.com/albums/t303/segan2B/VaporUnit.jpg)
