Author: Subject: pug 306 engine fault
tricky262000
posted on 5/5/08 at 03:53 PM Reply With Quote
We have a problem with our engine, it's a 2.0 l 16v on an R reg, occasionally the engine just dies as if the fuel is being starved, does it when stopped and when moving no pattern to it at all, i have checked the head gasket which appears to be fine, crank sensor and throttle switch are ok, i have changed the fuel filter and cleaned the throttle body, but still happening, sometimes it will ok for a few days and then it will do it 2 or 3 times a days, any ideas would be greatly recieved thanks Richard
eccsmk
posted on 5/5/08 at 04:16 PM Reply With Quote
try honest john forum
LINKY LINKY
[Edited on 5/5/08 by eccsmk]
mark chandler
posted on 5/5/08 at 07:57 PM Reply With Quote
Somehing floaing around in the fuel tank maybe?
Drifts around hen blocks the pickup, car stops, turn engine off pressue falls and releases he lump ready for next time.
Is it fuel level related?
tricky262000
posted on 5/5/08 at 08:53 PM Reply With Quote
fuel tank is clear have drained and changed the filter, also cleaned the throttle body as these play up, have tested the crank sensor and pressure teated the head all ok am now going to change the stepper motor and the throttle switch as there are trouble areas aswell
posted on 6/5/08 at 05:57 PM Reply With Quote
Fuel pump /relay? Are you getting fuel through when it plays up? Have you got a spark?
