tegwin
| posted on 6/5/08 at 09:29 PM |
Correct way to swivle?
Im having a mental block here....
I have made some aluminimum cam/rocker type things for my pushrod gear change system.
I want to weld some brackets onto my chassis and then use a bolt to hold the alloy rocker inplace?
I could just allow the alloy to pivot on the bolt, but its not very durable and about as proffesional as the brittish government...
So what is the correct/suitable method for pivoting an alloy part? I Guess ideally I would weld on some tubes and press bearings in, but I cant weld
alloy....
Pics appreciated
www.verticalhorizonsmedia.tv
Dangle_kt
| posted on 6/5/08 at 09:31 PM |
correct way to swivle?
teee heee
Mole
| posted on 6/5/08 at 09:44 PM |
[Edited on 6/5/08 by Mole]
locogeoff
| posted on 6/5/08 at 10:02 PM |
how about a steel or fozzie bronze insert
dhutch
| posted on 7/5/08 at 07:06 AM |
Or just machine out two recess and push in a pair of suitable size ball races if you realy want. Deoends how big the part is and how much
force/movement its going take (stuggling to visualise it or the install)
Daniel
DIY Si
| posted on 7/5/08 at 08:24 AM |
One simple option could be a couple of rod ends. You can then bolt the swivels in place without any worry of them binding.
| posted on 7/5/08 at 10:32 AM |
Press fit some brass tube into the ally rocker to act as a bush. Make sure it pivots on the plain shank part of the bolt and not the threaded part -
might need to pack out with washers to space it properly.
