eccsmk
| posted on 26/5/08 at 06:35 PM |
building blocks
im building a small garage for my kit car
and just wanted some idea of prices
found these on ebay which seem ok
ebay
locoboy
| posted on 26/5/08 at 06:50 PM |
£25 delivery, that will be per pack so watch out.
Dont know if the price is good though or not.
Locoboy
eccsmk
| posted on 26/5/08 at 06:57 PM |
ok thanks for the warning
doing yet more ringing round tomorrow
mark chandler
| posted on 26/5/08 at 07:05 PM |
I would be looking to build from thermalite blocks like these.
They weigh next to nothing and are really quick to put up (you need a weak mix, 6 maybe 7:1). The garage will then be insulated. You can also cut with
a saw for those awkward bits.
Price is also good if you barter with your local supplier.
Regards Mark
Kev99
| posted on 26/5/08 at 07:12 PM |
The way i read that its £25 delivery for the lorry load of 20 pallets (1440) blocks
Do u rearly nead that many
I think i only used about 8 pallets and mines a big garage
you could always e/mail him and ask
Kev............
[Edited on 26-5-08 by Kev99]
| posted on 26/5/08 at 07:14 PM |
you know you have a quality block when you can drill it with a non-hammer cordless with a regular hss drill bit Its a miracle that new houses dont
fall down!
| posted on 26/5/08 at 07:17 PM |
Thermalite blocks need rendering to make them weatherproof.
| posted on 26/5/08 at 07:18 PM |
If your going to be building in any thing for lifting engines etc (worth thinking about) then make sure you use decent blocks /engineering brick in
the loaded areas
rpm
| posted on 26/5/08 at 07:20 PM |
it's a good price for blocks, i'm paying about 62p each trade, but unless your garage is going to be huge you won't need anywhere
like that amount, as a guide there is 10 blocks to the m2
eccsmk
| posted on 26/5/08 at 07:25 PM |
my little garage will be 6metres by 8 metres
with a post in the middle to support an rsj which will hold my lift/winch
do it right this time and ill not have to do it again
| posted on 26/5/08 at 07:58 PM |
You should have a couple of pillars in the length if you are building in 100mm block, you can rest your RSJ across one of these. You'll want a
good beam to span 6metres and lift an engine and gearbox in the middle.
[Edited on 26/5/08 by Peteff]
eccsmk
| posted on 26/5/08 at 08:00 PM |
got my bricky coming round for a chat this week im sure he'll sort stuff like that out
thankyou for the advice tho
it helps give me some back ground knowledge when he does come round
