omega0684
| posted on 3/6/08 at 10:48 AM |
lm-1 lambda kits
hi all,
i am currently looking at buying an innovate lm-1 lambda kit for my car and wanted to get peoples opinions on it? i understand that innovate also do a
lc-1 kit and g2 gauges, are the g2 gauges specifically designed for the lc-1 or can they be used on the lm-1 kit.
all thoughts welcome
all the best
Alex
MikeR
| posted on 3/6/08 at 11:11 AM |
have a look at the sticky thread on the for sale section. Chris may be able to squeeze you in to his bulk buy of a different system if you're
interested.
omega0684
| posted on 3/6/08 at 12:21 PM |
i dont want a 'do-it yourself' kit, otherwise i would probably go for one.
PAUL FISHER
| posted on 3/6/08 at 04:44 PM |
Ive got the AEM uego wideband controller on my Indy,which is the same type as the LC1 innovate system,it works well,and was very accurate when
comparing the results on my rolling road session,the LM1 looks like it would give you better results for tuning,but then you would have no gauge in
the car after you had tuned the engine,to see if your air fuel ratio is keeping at the correct level,so that must be why your asking if the LC1 gauge
is compatible with the LM1 system,I would think it would be,because it is getting its information from the same lamda sensor,but my advice would be go
for the LC1,or the AEM system,take the car to a rolling road for them to set it up,they just monitor this with the gauge in the car as I do.
