Author: Subject: ht leads for edis coil pack
omega0684
posted on 10/6/08 at 10:12 AM Reply With Quote
can you use standard 8mm ht leads for the edis coil pack or do you need to get specific ones?
mcerd1
posted on 10/6/08 at 10:47 AM Reply With Quote
you'll need ones with the right ends for your coil pack
(but without the big rubber boot on the plug end like the ones you get on 16v engines)
if you've got the early style coilpack, then the ones from an early 90's 1.3 fiesta / escort should be about right
graememk
posted on 10/6/08 at 11:03 AM Reply With Quote
have you got it running yet ?
omega0684
posted on 10/6/08 at 11:07 AM Reply With Quote
no not running yet, only just got the wiring finished yesterday.
got to get my lanbda sensor bolted in to the exhaust as well.
will be diving through all of the megasquirt manuals and such to get it set up today.
im just hoping that the sensor you gave me will work.
big_wasa
posted on 10/6/08 at 03:16 PM Reply With Quote
you got the coil pack plugs ok then ?
omega0684
posted on 10/6/08 at 06:35 PM Reply With Quote
yes warren coil plugs came monday afternoon, i reckon the posty decided to have the afternoon off
