omega 24 v6
posted on 15/6/08 at 02:37 PM |
Rally design querie
Does anyone know if the reuseable brake fittings from rally design come with the olives already in or do you need to order them seperately?? Also do
the bulkhead fittings come with 10mm locknuts/halfnuts as I can't see them on raldes website.
COREdevelopments
| posted on 15/6/08 at 02:42 PM |
if your taking about the euroquip ones then yes they do come with an olive for each connector.
also i did not have nuts with my bulkhead fittings. what i did was drill out an m8 nut and tap it to m10x1 thread.
hope this helps
rob
[Edited on 15/6/08 by COREdevelopments]
omega 24 v6
| posted on 15/6/08 at 02:44 PM |
Cheers sound like a good plan.
indykid
| posted on 15/6/08 at 06:35 PM |
hope this helps
rob
that's ok if you've got an m10x1 tap. otherwise, the tap's probably the same price as a dozen halfnuts.
tom
omega 24 v6
| posted on 15/6/08 at 07:19 PM |
Probably true but I have access to one so it's an easy fix.
