LoMoss
| posted on 16/6/08 at 07:52 PM |
Audi TT Dash
A couple of weeks ago the dash on my girlfriends TT started to do odd things on start up. It wasnt driven for 2 weeks and the battery was flat.
Replaced it as it was passed its best. On replacing the battery the dash went in disco light mode and now wont come on. No speedo, rev etc.
Is this likely to be a serious (costly) repair? The net does not give any accurate diagnostics.
Any thoughts welcome.
Hall
madteg
| posted on 16/6/08 at 07:59 PM |
My boss had the same on his will ask him what it was, i know it cost 1500 quid, sorry.
ko_racer
| posted on 16/6/08 at 08:00 PM |
If you mean the dash pod they are a very common fault, they are expensive to replace, nearly £800 BUT Audi dealers WILL replace all faulty dash pods
for FREE. Go to your audi dealer and see what they have to say, if you have no luck with them phone audi customer service and they will help sort it
all out.
Have a look on the TT forum for more details.
Just in case you are wondering, they will replace on all cars including imports and high mileage. Had one replaced on our 98 LHD TT not too long
ago.
[Edited on 16/6/08 by ko_racer]
Alfa145
try leaving the battery disconected over night then reconnect and see if it works then. Might just be the ecu is confused by a short power loss.
Or just nip to your local Audi place and have a word with a mechanic on the side while he's having a smoke break to see what they say.
nib1980
sounds like the BCM needs flashing. a decent AUDI dealer should do it cheap / free
ko_racer
| posted on 16/6/08 at 08:10 PM |
Here is a link to the TT forum, about half way down there is a letter which I used to help me along with the Audi dealer:
Audi Letter
Regards
rf900rush
| posted on 16/6/08 at 09:39 PM |
Hi
My Sister had this common problem.
I believe it was questioned on BBC's Watchdog.
Her's was eventually replaced under warranty on car 5 year old car.
speedyxjs
| posted on 17/6/08 at 07:18 AM |
It was on watchdog and im pretty sure you can get it repaired for free
Mark Allanson
| posted on 17/6/08 at 07:53 PM |
The problem is not limited just to TT's, we do bodywork for the local main dealer, and if we get one go down while on site, they shaft us good
and proper!
