Author: Subject: Adhesive advice
Alan B
posted on 24/6/08 at 03:53 PM Reply With Quote
Adhesive advice
Probably been covered before, but I have little luck searching here.....
I need to bond/glue aluminium wing stays to grp, what's the best to use?
Generic description, if possible, as some brands may not be available here.
Alan
Myke 2463
posted on 24/6/08 at 04:03 PM Reply With Quote
Adhesive Bondage
PU Adhesive in UK we use:
Tiger Seal, Sikaflex, Texflex ( paint shops) Wurth bond and seal, Evostick seriously strong stuff, www. carbuildersolutions.co.uk own brand PU.
Be Lucky Mike.
irvined
posted on 24/6/08 at 04:11 PM Reply With Quote
I've used Sikaflex which is a brand of PU adhesive, sticks like turd on wool. I've bonded my wings to my wing stays (Steel rather than ali though.) and i broke the arches before i broke the bond when i changed up a wheel size.
http://irvined.blogspot.com
Alan B
posted on 24/6/08 at 04:21 PM Reply With Quote
Ah good...looks like I can get sikaflex over here....anyone recall which sikaflex number?
iiyama
posted on 24/6/08 at 04:36 PM Reply With Quote
221 is generally used, although Ive used EBT through out and have yet to have a problem with it.
If its broke, fix it. If it aint broke, take it apart and find out how it works!
smart51
posted on 24/6/08 at 05:28 PM Reply With Quote
I've used generic polyurethane adhesive to bond GRP cycle wings to powder coated steel. after 3 years, the powder coat came off the steel but the adhesive was as strong as ever.
miikae
posted on 24/6/08 at 05:39 PM Reply With Quote
If i remember rightly i used Sikaflex 291 available from boat chandlers , damn good stuff .
Mike
If it can be done it i will be done .
Alan B
posted on 24/6/08 at 07:05 PM Reply With Quote
Thanks everyone....good info...
austin man
posted on 24/6/08 at 08:30 PM Reply With Quote
are you sure the alluminium items are strong enough I have seen several sets of steel wing stays fracture due to vibration, on several differnt vehicles including MK, Locost caterham etc
