Poll: Definition of vehicle track [View Results]
Center of rim to center of rim
Outside of rim to outside of rim
Author: Subject: Definition of vehicle track
carcentric
posted on 10/12/03 at 01:17 AM Reply With Quote
I've always understood the term "track" to mean the distance between the centerline of one wheel rim (or tire, assuming they're symmetrical tires) and the centerline of the other wheel rim on the same axle (measured at the axle to eliminate the effect of camber and any toe in/out).
But, lo and behold, the Merriam Webster dictionary says, "(5a) the width of a wheeled vehicle from wheel to wheel and usually from the outside of the rims."
With a pair of 6" wide rims, that measurement would be 6" greater than the way I measure track.
So here's a poll.
I'd also appreciate any authoratative URL's that endeavor to define term. Thanks,
M D "Doc" Nugent
http://www.carcentric.com
pbura
posted on 10/12/03 at 05:58 AM Reply With Quote
SAE Vehicle Dynamics Glossary
6.3.,3 WHEEL TRACK (WHEEL TREAD) : The lateral distance between the center of tire contact of a pair of wheels. For vehicles with dual wheels, it is the distance between the points centrally located between the centers of tire contact of the inner and outer wheels. (See S A E J693.)
There's an ISO Standard 612-1978 that defines track (term number 6.6, in fact), but I'll be hanged if I'll pay for it to find out what it says! Anybody got a copy?
Pete
[Edited on 10/12/03 by pbura]
Pete
carcentric
posted on 10/12/03 at 06:07 AM Reply With Quote
Take that, Merriam Webster!
Looks like I was closer than the dictionary, but not right about the effect of camber (the more camber a car has, the wider it's track - I thought the car's track would not change as camber is increased).
Thanks for the reference, Pete!
M D "Doc" Nugent
Spyderman
posted on 10/12/03 at 02:00 PM Reply With Quote
Almost!
The more negative camber would increase track!
Terry
Spyderman
carcentric
posted on 10/12/03 at 05:02 PM Reply With Quote
Mm-hmm
That's what I was thinking (but didn't write). As a former competition driver, negative camber is "the only camber" (worth having).
Which brings me to another curiosity, though. In old photos and paintings of 1930s and older race cars, it's obvious they have POSITIVE camber on the front. Why did they do that? Was it for ease of steering or something?
M D "Doc" Nugent
Mix
posted on 11/12/03 at 09:49 AM Reply With Quote
Nah!!
It's the metal flexy bit around the wheels of a tank or digger
Mick
