ruskino80
| posted on 3/7/08 at 07:35 PM |
conservatory roof question
can i install a suspended ceiling (plasterboard) in a conservatory-retaining the originall poly exterior(perhaps with some obscuring trick to hide
whats beneath(if that makes sense))??
cheers rich
r1_pete
| posted on 3/7/08 at 07:41 PM |
despite the type of poly roof I think you'd have a problem with damp build up which will eventually wreck the plasterboard.
ruskino80
| posted on 3/7/08 at 07:44 PM |
ventilation can be achieved at the lower and higher edges of the ceiling,foil back board --stands a chance no?
nitram38
| posted on 3/7/08 at 07:50 PM |
Also, what about weight of the plasterboard ceiling hanging from the structure.
If you are trying to block out the light/heat, why not just fit blinds?
At least you can open them if you change your mind.
ruskino80
| posted on 3/7/08 at 07:57 PM |
the structure looks to be more than adequate for the job-my whole idea is to try and make the conservatory more of a useable living space(year
round)the trick is that a conservatory must have a transparent roof to make it not need to comply with building regs, so i am looking for a loophole.
Danozeman
| posted on 3/7/08 at 08:04 PM |
If you could make it so that the weight of the plasterboard wasnt hanging on the ceiling yud be ok but condenstion would be a problem.
To save the hassle get some nice thick blackout blinds put up. They make hell of a difference to how the room is and the heat retention etc. Then in
the summer just roll them up.
Dan
joneh
| posted on 3/7/08 at 09:11 PM |
No. It'll look sh!t.
I have five skin shaded poly in mine that lets the lower winter sunlight through and reflects most of the high summer sun.
ruskino80
| posted on 3/7/08 at 09:14 PM |
all points noted ,will give it some serious thought,thanks guys.
Danozeman
| posted on 3/7/08 at 09:25 PM |
I didnt like to say that.
Dan
austin man
| posted on 3/7/08 at 09:54 PM |
change the poly carb Mine is bronze externaly and opal internaly which cuts the light down tremendously. if you ar thinking about suspended ceiling
then yo realy coul do withe pearling dependant on the typ of roof you have. You could always clat it wit upvc shiplap boards or something similar
