Author: Subject: Steam Powered Car
kitcar007kev
posted on 9/7/08 at 06:05 AM Reply With Quote
Steam Powered Car
http://cars.uk.msn.com/News/car_news_article.aspx?cp-documentid=8778261
smart51
posted on 9/7/08 at 06:58 AM Reply With Quote
three megawatts of heat in. 360 BHP or 0.48 megawatts out. 16% efficiency.
Ivan
posted on 9/7/08 at 07:25 AM Reply With Quote
Given the calc above it seems that they forgot the KISS principal here and complicated things to the point where they are unlikely to succeed.
I think steam trains of the 50's and 60's could get over 100MPH pulling a whole lot of coaches (the Flying Scot) and using technology from the 1800's. (Simple coal fired boilers and piston engines. So there must be simpler ways to do this.
I think they started to go down the high pressure route and the fun of resolving all the issues ran away with them and nobody sat back and said - hey cant a reciprocating or radial engine with low pressure steam do the job in a simpler way.
Mr Whippy
posted on 9/7/08 at 07:38 AM Reply With Quote
it's a nuts project showing exactly how not to build a steam car
More a bomb on wheels, if it crashes they'll be a huge crater
The yanks will be dropping them from planes next...
posted on 9/7/08 at 08:41 AM Reply With Quote
I think they managed 120 mph or more but how relevant is that?
A train has to over come rolling resistance, whcih is a fair bit but it has several miles of track to whcih to get up to speed; after that is it pushing against air resistance which for a train being long and thin, should not increase that much with increased length.
ReMan
posted on 9/7/08 at 08:47 AM Reply With Quote
Looks simple enough to me.
This picture shows where they have plugged the kettles in
kettle
kettle
[Edited on 9/7/08 by ReMan]
Mr Whippy
posted on 9/7/08 at 08:58 AM Reply With Quote
kettle
kettle
dhutch
posted on 9/7/08 at 10:41 AM Reply With Quote
Bonkers!
- But yeah, good on them i guess. Mad fools.
The manage to mention the JCB diesalmax a few times in the artical as well dont they!
Daniel
posted on 9/7/08 at 11:18 AM Reply With Quote
So it's inefficient... so how many record-breaking cars are efficient!
Good luck to them - should be 'interesting'.
And it's not like a bomb, as suggested above. Flash steam systems hold only a small volume of superheated steam, only what's in the hot tubes - it's not like a boiler-full of boiling water. The water gets pumped into white-hot tubes, gets converted to steam, then it's out into the turbines.
smart51
posted on 9/7/08 at 11:50 AM Reply With Quote
How do you get rid of the other 2.5 megawatts of heat? Its the same heat as 2500 1 bar electric fires.
dhutch
posted on 9/7/08 at 02:22 PM Reply With Quote
16% isnt too appaling.
Dont forget that your average internal combustion engine is only around 30% efficient.
Daniel
Bob C
posted on 9/7/08 at 02:38 PM Reply With Quote
Your petrol engine PEAKS at 30% efficient. So when it's putting out 150kw mechanical power the radiator is supplying 350kW of heat.
However in normal driving the efficiency is much worse and probably averages well under 10%.
best efficiency is with wide open throttle (basically highest cylinder pressure - it's a thermodynamics thing). Diesels score on efficiency because their cylinder pressure is not reduced by throttling on part load - as well as having higher compression ratio anyway
Bob C
posted on 9/7/08 at 02:47 PM Reply With Quote
PS that doesn't look like a 170mph car to me, it looks like high 200s at least.....
DaveFJ
posted on 9/7/08 at 03:29 PM Reply With Quote
3 Megawatts? they must be mad!!
Mines the manky old Parka..
Dave
Ferg
posted on 9/7/08 at 08:05 PM Reply With Quote
I have a friend who is fully intending to build a steam powered road car in the next few years...........
posted on 9/7/08 at 08:23 PM Reply With Quote
I have ridden in (on!) a replica of a 1900's steam car, the sort you would see on a Brighton Vintage Car run - a lot like this one.
It was totally silent as it puttered along at 10 mph or so, but when he opened it up it accelerated VERY fast up to 50mph leaving a very long sausage of steam 15 ft high and 100 yards long in the road behind him. At that point the driver gave up as the tiller steering was just too dangerous!
It's worth remembering that in the very early stages of car development the steam car nearly displaced the internal combustion engined ones...
Ferg
posted on 9/7/08 at 09:08 PM Reply With Quote
Simon is under no illusions about his project. He and his brother have a couple of 'rollers and a tug.
Steam's all very well, but warm up time means you can't easily just pop down the shops!
