kango
posted on 12/7/08 at 08:46 AM |
Best gear ratios
I have a choice of a few gearboxes. I know the ratios of all the boxes.
If I want to make my decision based on the best ratio for track and road use....what do I look for?
How many revs should one drop changing from one gear to the next?
mr henderson
posted on 12/7/08 at 10:00 AM |
Well, the starting points are, what maximium speed can you achieve and use, and how many gears are there.
Also, do you want the top gear to be, in effect an overdrive (be chosen to allow high speed cruising rather than getting to your maximum speed in the
shortest possible time)?
John
posted on 12/7/08 at 12:13 PM |
Only the first three ratio really matter,
The old 2000e ratios are a good starting point ---- A lot depends on you final drive but if you aim for for 40 mph in 1st gear.
posted on 12/7/08 at 12:25 PM |
2000e ratios
http://hometown.aol.com/dvandrews/bghpage.htm
kango
posted on 12/7/08 at 12:43 PM |
All 5 speed boxes.
Would like to get top speed in 4th - track use
Cruise in 5th for town and highway use.
viatron
posted on 12/7/08 at 06:58 PM |
This may help
http://www.tigerownersclub.co.uk/download_files/GEARING.EXE
posted on 12/7/08 at 07:18 PM |
This is an easy-to-use gearing calculator:
GearCalc
And it's free.
kango
posted on 13/7/08 at 06:13 AM |
I have used "GearCalc", but I more interested in the methodoligy behing sellecting a gear ratio... eg
1) You need to know the rev range of your cams to ensure you do not fall off the cam if you change at Max power revs.
2) You want the rev drops between gears to be =- 500 revs les as you go up through the box.
Something like that or suggestions of theoretically perfect ratios.
posted on 13/7/08 at 04:52 PM |
No such thing as theoretically perfect ratios, even for track use on a given circuit ratios will always be a compromise.
Modern boxes tend to have 1st gears that are much too short, 2nd gears like wise 3rd too long 4th is still the direct drive and 5th that are too
tall.
With a very light car you want 1st as tall as you can get and still be driveable and 2nd to sit midway between 1st and 3rd. The old 2000e and bullet
ratios were the dogs danglers for Ford engines, the 2000e ratio set was used on the Lous Elan & Cortina and Eclat.
The bullet ratio set is even closer and was an option on the Lotus 7 S4 and early Caterhams.
But it really might be a bit too sporting for road use with a 1600 engine unless you have a low axle ratio.
So look for a box set that has ratios near these
1st 3.0:
2nd 2.0:1
3rd 1.35:1 .
Depending on axle ratio, tyres and max rpm
1st circa 40mph
2nd circa 60mph
3rd circa 85 mph
