Author: Subject: CDI Problem?
mistergrumpy
posted on 13/7/08 at 04:53 PM Reply With Quote
CDI Problem?
Can anyone figure this out? My latest problem is that my car (ZX9) won't start unless I switch the ignition on then unplug the small plug on the CDI then plug it back in?
The CDI has 6 cables coming out being:
4 x spark plugs wires
1 x earth
1 x to ignition fuse/fusebox
I've tried unplugging each coil one at a time then trying to start and the earth is fine. Wierd one this?
Flamez
posted on 13/7/08 at 05:01 PM Reply With Quote
You dont say if it has run normally before? Are all the sensors fitted?
mistergrumpy
posted on 13/7/08 at 05:07 PM Reply With Quote
Well yes. The only thing I've done electrics wise since the last time it worked fine is indicator and clocks minor wiring and soldered 2 main earths into one and extended them slightly. There's still continuity in the earth.
matt_gsxr
posted on 14/7/08 at 10:03 AM Reply With Quote
sounds like your wiring to me
mistergrumpy
posted on 14/7/08 at 09:58 PM Reply With Quote
Don't be saying that. Took me bloody months just to get this far. I've heard CossieBri had the same problem once.
cossiebri
posted on 15/7/08 at 06:25 PM Reply With Quote
It's not the c.d.i ,i bought another thinking that was the problem.Even had a m/c electrics specialist take a look (for 2 hrs-all i could afford) and still had no luck. Used to use it as another imobilser!
If it doesn't fit MODIFY it!!
Cheers BriF
mistergrumpy
posted on 15/7/08 at 10:26 PM Reply With Quote
Strange though eh? Looks like I'm stuck with it then. Not happy with that
