Author: Subject: Axle Weights
posted on 15/7/08 at 03:02 PM Reply With Quote
Axle Weights
Do the two axle weights add up to the whole weight of the car?
On the rollers this morning I had 280kg at the front and 275kg at the back.
So, does that mean my car weighs 550kg????
Mr Whippy
posted on 15/7/08 at 03:05 PM Reply With Quote
no the car weighs 2 tons
did you included the middle axle?
go and have a coffee, thats 555kg BTW
190kg less than my buggy, must be the offroad tyres and that custom chassis
[Edited on 15/7/08 by Mr Whippy]
Guinness
posted on 15/7/08 at 03:31 PM Reply With Quote
Was this at an SVA then Steve?
Not sure of the answer, it probably involves math.
But that's what I'd assumed!
Mike
posted on 15/7/08 at 03:36 PM Reply With Quote
Mike
Sneaky question Mike, it was indeed SVA this morning.... and, guess what??
posted on 15/7/08 at 04:12 PM Reply With Quote
No. The sum of both axles added together does not give the true total weight of the vehicle. Similarly, you cannot weigh yourself by standing with one foot on the floor and the other foot on the scales and multiply the reading by two.
Phil
Mr Whippy
posted on 15/7/08 at 07:36 PM Reply With Quote
Phil
so were does the difference in weight go then?
it doesn’t work when you weigh yourself because you have to shift your balance to stop yourself from falling over, hence you get a much higher reading than both feet together. Since the car has four wheels that isn’t an issue…
Dale
posted on 15/7/08 at 07:59 PM Reply With Quote
If the car is level (as per the scales are flat on the floor or the other half of the car is raised to the exact height of the scales surface) the weight should add up to be pretty damn close. As soon as the wheel heights are different it will be out.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
myke pocock
posted on 15/7/08 at 08:54 PM Reply With Quote
Am I glad someone else has asked this. SO... If I were to use a weighbridge where the surface is level to the ground, put the front end on then the back end I should just about be OK????
posted on 16/7/08 at 11:23 AM Reply With Quote
It's just as Dale says. If the car is level the weight will be pretty accurate, although bear in mind that some weighbridges can have increments of 20kg.
I know Coozer SVA'd his car at Beverley and I also know that their scales don't weigh the axles whilst the vehicle is level. It's surprising how much weight transfer can affect the weights.
Phil
