Ricks-9r
| posted on 19/7/08 at 08:04 PM |
tvr Cerbera problems ?
thinking px the Mac for one its a 97 4.2 v8 ,just wanted to know any one on here who might have one or has owned one & point out any issues with
them
bec f/s £6500> http://www.pistonheads.com/sales/676264.htm
| posted on 19/7/08 at 08:18 PM |
TVR's are only a problem for those who expect Honda-type reliability for their cars and are no use with a spanner.
If you've run a kit-car, then a TVR should pose you no more or less troubles - you just have to keep on top of things!
nitram38
| posted on 19/7/08 at 08:42 PM |
Check the carpets as the roofs tend to leak.....
philw
| posted on 19/7/08 at 09:45 PM |
The roof on the Cerbera doesn't leak because it's a hard top not soft top.
Must try harder
philw
| posted on 19/7/08 at 09:57 PM |
them
Ooh, there are a few, apart from chassis and the obvious, check the lighting electrical boxes in the boot, check the slipper diff.
I am a bit worse for wear at the moment but i have owned a Cerbera and a Griff, if you want to PM me and jog my memory i will try and guide you, i had
no trouble with my Cerbera , they are huge fun and will do 180+, try and buy one with a suspension upgrade preferably nitron's.
Must try harder
Chippy
| posted on 19/7/08 at 10:02 PM |
Always seem to me to be, well sort of "nearly" finished, mind you never owned one. If I was in the market for that kind of car I would go
for a Lotus, then it's only bits that fall off you have to worry about.   Ray
ahb
| posted on 19/7/08 at 10:42 PM |
Check for cracks in the manifold close to the flange. Common fault and a costly repair. Each manifold about £350.
Hello!
Ricks-9r
| posted on 20/7/08 at 10:36 PM |
re ,Cerebra
Thanks for the replies so far ;-) i went to look @ it today ,A lovely looking thing just been resprayed 18" wheels ,new exhaust & new
leather re-trim ,but it's done 36+k miles & it;s very tappity (rattly top end on solid lifters ? ) so being the first Cerebra I've
seen not sure if this is normal to be rattly ,& what are the engines good for in miles ? oil pressure was 65psi idle ,about 80 psi ish when revved
,any more info appreciated ;-) a fewpics
http://i74.photobucket.com/albums/i256/richard440/Kit%20Car%20Stuff/P1000970-1.jpg
http://i74.photobucket.com/albums/i256/richard440/Kit%20Car%20Stuff/P1000973-1.jpg
http://i74.photobucket.com/albums/i256/richard440/Kit%20Car%20Stuff/P1000972.jpg
[Edited on 20/7/08 by Ricks-9r]
ned
| posted on 21/7/08 at 09:47 AM |
why had it been resprayed and retrimmed - accident damage/repairs?
beware, I've got yellow skin
Ricks-9r
| posted on 21/7/08 at 10:46 AM |
the guy who owns it works @a body shop so i think he just did it to change the colour to what he wanted & the re trim just a bit tatty interior i
think so had that done as well
[Edited on 21/7/08 by Ricks-9r]
