Author: Subject: floor leveling (off topic )
eccsmk
posted on 20/7/08 at 06:27 PM Reply With Quote
please can you help i need to level a floor which is about 1/2 inch out of level
is there something i can mix and poor on??
thanks folks
iiyama
posted on 20/7/08 at 06:30 PM Reply With Quote
Not for a 1/2" run there aint!
Youll have to make up some of it with either a build up of latex in 3 or 4 layers or mix granit chippings in with the latex to get it in the ball park and then run a couple more layers of latex to get it nice!!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
omega0684
posted on 20/7/08 at 06:31 PM Reply With Quote
self leveling concrete! i used it to do my garage floor, then covered in sealer, then laminate, solid as ever, top stuff
eznfrank
posted on 20/7/08 at 06:32 PM Reply With Quote
What sort of floor and how big?? I'd use rapid set tile adhesive with a mix of PVA on a small - medium floor.
eccsmk
posted on 20/7/08 at 06:43 PM Reply With Quote
Concrete floor 2mx4m in a kitchen and the kitchen's being delivered on Thursday!
daviep
posted on 20/7/08 at 06:52 PM Reply With Quote
Google: Floor Leveling Compound
Loads of stuff out there
Davie
eccsmk
posted on 20/7/08 at 07:00 PM Reply With Quote
done that but as ive not used it before it seems a bit daunting
is there a specific product i can pour on and thats it or will it be a case of troweling out ??
omega0684
was it just a wet mix or a specific compount??
posted on 20/7/08 at 07:10 PM Reply With Quote
half inch aint much, you wouldnt really notice once the kitchens in. I find nearly all floors run out, especially new houses!
eccsmk
posted on 20/7/08 at 07:27 PM Reply With Quote
if it was from 1 end to the other it would be left as is but it dips and rises its really bad
mr henderson
posted on 20/7/08 at 07:32 PM Reply With Quote
Never-the-less, as Joel says, virtually all kitchen floors are not flat, and fitters are used to dealing with it. I wouldn't bother if I were you
John
oldtimer
posted on 20/7/08 at 07:51 PM Reply With Quote
Self leveling compound. You have to do some work and spread it as well as you can, leave it and it sets after leveling itself and the trowel marks should also have gone, good stuff and I used it without seeing it used before - it does say what it says on the can, etc... I also agree that a decent spread of tile adhesive should cover any imperfect areas and unless its a bespoke handmade job those little adjustable legs should see to the rest. The hard bit for me was as I knelt and worked I tore the meniscal cartilage in my knee and the £3000 I spent getting that sorted made me wish I'd paid for a labourer......
eccsmk
posted on 20/7/08 at 08:28 PM Reply With Quote
unfortunately you have got it spot on
its a bespoke hand made jobbie
looks like im in trouble
doh!
mark.s
posted on 20/7/08 at 08:37 PM Reply With Quote
as joel said really, but if you go the latex route, make sure you give the floor a coat of unibond/pva and let it dry to seal the floor before you put the latex down
austin man
posted on 20/7/08 at 08:46 PM Reply With Quote
Levveling compount is the way to go mix it and pout it finds its own level, you could also use a screed which is basically grit sand and cement which you have to level with a trowel. If youve no experience of this go for leveling compound as it generaly finds it won level. use a float to ditribute it evenlt and feather the edges in
DIY Si
posted on 20/7/08 at 09:48 PM Reply With Quote
Surely if it's bespoke they can work over the uneven floor? Or has it been made off site, assuming a flat floor to fit it on?
eccsmk
posted on 20/7/08 at 10:14 PM Reply With Quote
its been made off site and i completely forgot it was coming
panic painc
looks like a trip to the merchants tomorrow see what i can buy
Liam
posted on 20/7/08 at 10:36 PM Reply With Quote
Before potentially making a big mess, have you actually asked the fitters whether this is a problem? I mean, as has been said, no kitchen floor is perfect and these guys should have the experience to deal with it. A wickes take-away kitchen has adjustable cabinet legs - surely your super-duper expensive job should too?
Liam
posted on 21/7/08 at 06:21 AM Reply With Quote
i dare you to leave a webcam in the room and tell the fitters you have friends all over the world watching them
DarrenW
posted on 21/7/08 at 08:18 AM Reply With Quote
Bespoke or not im sure its being made with some levelling device in mind (adjustable legs etc.).
1/2" doesnt sound bad at all. Worst case they should be able to get a level to fit the kitchens to so the worktops are correct and then adjust the kick boards to suit the floor.
If you are overly concerned and the kitchen order asks for a fully level floor id give them a ring and discuss.
I know a company that builds kitchens bespoke. In essence they are all standard sizes and have adjustable legs. They are not really that much better than buying solid caracasses from the trade outlets - its just that they sometimes have some good ideas for those difficult areas and have lots of design experience to make the end result look very smart. Most bespoke kitchen places still use similar faced chipboards unless you are paying top money for solid wood kitchen.
Whenever i fit kitchns i start by scibing a level line around the wall at worktop height as a gauge and check the heights to ensure the boards will fit ok.
andyharding
posted on 21/7/08 at 08:24 AM Reply With Quote
B&Q value self leveling floor compound comes in about £20 per bag. Go and buy a couple of bags and also some PVA. You will also want a paddle for your drill if you haven't got one and a plastering float.
1) Mix PVA 50:50 with water and coat the floor with it. No need to wait for it to dry.
2) Mix 1 bag of the leveling compound in a bucket with the paddle until it is runny enough to flow.
3) Pour over the area starting in the middle and working out.
4) Use the float to push the compound into any hollows.
5) If needed mix the other bag and apply the same way otherwise take it back for refund. (much easier to lay 2 bags at once than have to let it set and do another layer if 1 bag isn't enough)
