Author: Subject: Photoshop help please!
james h
posted on 21/7/08 at 01:40 AM Reply With Quote
I have been trying ALL night to get an anti-aliasing effect on an image (originally made in microsoft paint) by using the free trial Photoshop software.
I am using the magic wand tool to select the edges.
Then I try using the 'refine edge' button which gives me several options, and previews the image as I change them. I get the image as I want it, i.e. smoothed anti-aliased edges. Then I click OK....
Nothing happens! It goes back to the image as I imported it, with the edges still selected as per the magic wand tool.
So can anybody help me? It is the first time I have used this software, and I can't help but feel that I am missing something really obvious.
Thanks,
James
Mr Whippy
posted on 21/7/08 at 07:54 AM Reply With Quote
Maybe the obvious answer is that it’s because you are using the trial version
I got Paintshop Pro off limewire
[Edited on 21/7/08 by Mr Whippy]
posted on 21/7/08 at 10:21 AM Reply With Quote
It's probably the MODE you're in.
Go Image/Mode - then set to RGB.
I think you are currently trying to edit in indexed Mode. *.bmp file are indexed so won't anti-alias. Of course, correct me if I'm wrong.
flak monkey
posted on 21/7/08 at 11:34 AM Reply With Quote
U2U saren1986 she is a bit of a wizz with photoshop
Sera
http://www.motosera.com
james h
posted on 21/7/08 at 12:52 PM Reply With Quote
Ok thankyou, I will give your ideas a try
Liam
posted on 21/7/08 at 09:33 PM Reply With Quote
The refine edges tool is only to refine the edges of your selection - doesn't do anything to the image itself! Easiest way to antialias an image I can think of would be to simply resize the image to, say, 4x original, then resize it back to original. The resampling process will automatically lead to antialiased edges.
Liam
james h
posted on 22/7/08 at 09:26 PM Reply With Quote
Bah, still no luck the only way I have found to do it was to use the refine edge tool and print screen, then paste onto paint then back onto the rest of my logo. Not satisfactory really, I would appreciate if anybody has a better solution
James
Liam
posted on 22/7/08 at 09:46 PM Reply With Quote
The above didn't work?
Post here, or in your archive, or email me the piccy and tell me what you want done, and i'll do it!
Liam
