speedyxjs
| posted on 23/7/08 at 06:47 PM |
Knocking noise in reverse
What could be the cause?
mookaloid
| posted on 23/7/08 at 06:49 PM |
Without a few more specifics to go on, I would say something broken or wearing out or loose
speedyxjs
| posted on 23/7/08 at 06:53 PM |
What else do you want to know?
It only does it in reverse. Cant be sure where it is coming from but think transmission tunnel
mookaloid
| posted on 23/7/08 at 06:55 PM |
type of car?
speedyxjs
| posted on 23/7/08 at 06:56 PM |
Sorry, should have started with that
Its on my midget so front engine, rwd
mookaloid
| posted on 23/7/08 at 07:03 PM |
I would guess worn or sloppy engine/gearbox/axle mounts causing the gearbox/axle to knock on the body somewhere or maybe if it's the gearbox a
missing tooth off reverse gear?
Mark
adithorp
| posted on 23/7/08 at 07:27 PM |
OK, I'll bite...
Put a bike engine in it. That'll stop it knocking in reverse!
adrian
speedyxjs
| posted on 23/7/08 at 07:40 PM |
quote: Originally posted by adithorp
OK, I'll bite...
adrian
In a word...NO
Havnt you read whippy's signiature?
tegwin
| posted on 23/7/08 at 07:54 PM |
Its proberably the back axle tramping as you go backwards...
Tends to happen in older cars as the springs/dampers wear out...apparently
www.verticalhorizonsmedia.tv
Howlor
| posted on 23/7/08 at 08:02 PM |
Knee on the centre console?!
skodaman
| posted on 23/7/08 at 09:05 PM |
'Put a bike engine in it. That'll stop it knocking in reverse!'
Aw I was gonna suggest that.
Skodaman
worX
| posted on 24/7/08 at 05:11 AM |
The time that someone uses something Mr Whippy says on this forum, for a side winning argument is the time to pack up and go home!!!
OK, I'll bite...
adrian
In a word...NO
speedyxjs
| posted on 24/7/08 at 06:34 AM |
OK, I'll bite...
adrian
In a word...NO
splitrivet
| posted on 24/7/08 at 07:31 AM |
Propshaft ??
