speedyxjs
| posted on 31/7/08 at 07:51 PM |
Misfire?
I have a misfire (stutter) when i rev above 1500 - 2000 rpm. the plugs, air and oil filter are all new and distributer has been adjusted.
What else could it be my (limited) mechanical knowledge leadds me to think it may be the leads?
CRAIGR
| posted on 31/7/08 at 08:00 PM |
What car /engine????
speedyxjs
| posted on 31/7/08 at 08:01 PM |
Midget 1500
Just sorting out a few more problems
mark chandler
| posted on 31/7/08 at 08:05 PM |
Assuming Midgit then look at oil in SU carbs dashpot.
As the car is prehistoric you may have to mix about a bit so try engine oil first.
Pluck the air filters off, First balance the carbs, a bit of small tube and listen to the hiss is fine, tweek them until its even now:
Now watch the pistons, they should both rise in unison as you rev the engine.
Also while you can see the pistons you can check mixture, poke a screwdriver under the piston with it running at idle lift 1/4" (no more) engine
revs should rise very slightly or stay the same, this is good. If the revs drop its to weak, rise and to rich.
Regards Mark
[Edited on 31/7/08 by mark chandler]
CRAIGR
Has it had new points ,check points gap, pos condenser, any oil in the top of the carbs
adithorp
| posted on 31/7/08 at 08:22 PM |
How did you set the points? If it was just sitting the gap with feeler guages then they might not be right once the engine is running. Wear in an old
dizzy means they are best set by dwell angle when running. Did you grease the dizzy cam?
Also didn't you set the tappets last week? Not too tight are they? If its the Triumph engine they have very light springs and are easy to get
too tight.
adrian
speedyxjs
| posted on 1/8/08 at 05:25 AM |
Points were set cold so will try that and we did grease the cam.
Good point about the tappets, will check them tonight
