Author: Subject: vacuum pipe length
omega0684
posted on 1/8/08 at 05:36 PM Reply With Quote
vacuum pipe length
does it matter how long the vacuum pipe is that goes from my ITB's to my MS unit.
is it worth installing a small fuel filter to help stablise the kpa
martyn_16v
posted on 1/8/08 at 05:46 PM Reply With Quote
No and yes. A 0.8mm mig tip can also help damp out the pulses a bit.
omega0684
posted on 1/8/08 at 05:47 PM Reply With Quote
what do you mean by a mig tip
posted on 1/8/08 at 05:48 PM Reply With Quote
Or you can get one of those restrictors used in things like Carbtunes.
Or get a bit of nylon / plastic and drill a fine hole in it. Obviously you don't want to dampen it too much or the vacuum signal will lag behind the engine speed / load...
martyn_16v
posted on 2/8/08 at 08:57 AM Reply With Quote
Clicky
