Author: Subject: Sky dish
mookaloid
posted on 7/8/08 at 04:18 PM Reply With Quote
Sky dish
Will they work through glass or do they have to be outdoors?
Mark
westf27
posted on 7/8/08 at 04:22 PM Reply With Quote
should do with a little reduction of signal but why do want a sky dish in your lounge
mookaloid
posted on 7/8/08 at 04:30 PM Reply With Quote
Well I don't but someone I know has had sky installed but they didn't check to see if the lease permitted a dish on the outside of the flat - it doesn't!
They now have a years sky to pay for but can't have a dish. I was wondering if they set it up just inside the lounge window they could use it but have an interesting talking point for the next 12 months
posted on 7/8/08 at 04:36 PM Reply With Quote
http://www.selkirkshire.demon.co.uk/analoguesat/windowdish.html
posted on 7/8/08 at 04:37 PM Reply With Quote
http://www.digitalspy.co.uk/forums/showthread.php?t=780811
Looks like it depends on the glass type used and the size of the dish....
westf27
posted on 7/8/08 at 04:39 PM Reply With Quote
oh I see,bit of a pest.Worth a try,get a little sat finder of ebay for a few quid
posted on 7/8/08 at 04:41 PM Reply With Quote
Flat satellite dish?
linky
http://www.self-sat.com/
splitrivet
posted on 7/8/08 at 04:57 PM Reply With Quote
Cant see it would work your window would have to face the right direction and the attenuation from the glass and building would kill the signal.
Bob
Macbeast
posted on 7/8/08 at 05:17 PM Reply With Quote
As said, the dish should work with some attenuation of the signal, depending on the type of glass. There used to be a sexy Swedish horn antenna which was designed to go indoors but I don't know if there is a SKY version. Some glass has metalised coating to reflect heat and that would not be good news. But as long as he can see out in the right direction (somewhat east of south) it's worth a try.
mangogrooveworkshop
posted on 7/8/08 at 05:20 PM Reply With Quote
no it doesnt work........ stick a hidden dish in the back of the flats and on the ground.
there is hidden dishes available
RichardK
posted on 7/8/08 at 06:15 PM Reply With Quote
Has it a flat roof that is accessable but out of sight from the ground?
Just a thought and you probably know where this thought process is going!!!
See ya soon
R
Gallery updated 11/01/2011
mangogrooveworkshop
posted on 7/8/08 at 09:25 PM Reply With Quote
See ya soon
R
you install the dish upside down so it lies flat on the ground the down side is in snow conditions it will result in blocking and freezing.(it happens on the pro dishes as well if the heaters not fitted or the ray dome is wet and freezes over)
how ever with snow its only 3 days a year.... so its well worth it
linky
failing that we could send down a spare five meter dish we have out back
mangogrooveworkshop
posted on 7/8/08 at 09:39 PM Reply With Quote
