Author: Subject: wasps in garage roof
madteg
posted on 14/8/08 at 06:41 PM Reply With Quote
How do i get rid of them as i have not been in there for two days and i am getting really piss-d off
watsonpj
posted on 14/8/08 at 06:49 PM Reply With Quote
go to homebase and get the spray stuff they do and spray it over the nest as instructed. Work really well for me on one occasion but only really works if you can see the entrance. Alternatively I called the council and they came and did one for £35.
pete
stevebubs
posted on 14/8/08 at 06:53 PM Reply With Quote
How about leaving a can of acetone open in there? Smell should drive them out, surely??
russbost
posted on 14/8/08 at 06:54 PM Reply With Quote
If it's a sizeable nest do as above - if it's only fairly small ordinary flyspray does the job, particularly if it's in a confined space where you can spray. Make sure your escape route is clear!
mistergrumpy
Don't do what I did in my attic. Smack the hive and squash it with a piece of wood then run away and shut the hatch. Then hear a hiss amongst the buzzing and realise that you disturbed a pipe which is leaking. I had to jump back up to check it and the swines all hovered over the hatch waiting for me. I was trapped in there for bleeding ages
posted on 14/8/08 at 06:56 PM Reply With Quote
Burn down the garage and leave the country, they know who you are Sneak in in the night and fill it with expanding foam and knock it into a dustbin bag or get someone else to do it for you. I hate wasps
907
posted on 14/8/08 at 06:57 PM Reply With Quote
WD40 fired over the top of a cigarette lighter. WooHoooo, what fun.
It's a well known fact that WD stands for Wasp Destroyer.
Paul G
ZZZZZZZZZZZZZZ..........................THUD
Edit to add sound effects
[Edited on 14/8/08 by 907]
posted on 14/8/08 at 06:59 PM Reply With Quote
Most garden places will sell you a long-range spray - aim it at the nest from 6 or 8 foot away, press the button and a long stream of insecticide foam whooshes out. The instructions say that you should try and cover the whole of the outside of the nest.
It's fairly nasty stuff, so the usual 'make sure you haven't got to walk under it, lots of fresh air' advice goes without asking.
posted on 14/8/08 at 07:00 PM Reply With Quote
Paul G
That'll probably end up as 'garage roof destroyer'! Anyway, I thought you'd use a nice big acetylene flame...
907
posted on 14/8/08 at 07:09 PM Reply With Quote
Paul G
Don't be daft. That would be GRD40. No such stuff.
Acetylene covers everything in black soot. I've tried it.
zetec7
posted on 14/8/08 at 07:12 PM Reply With Quote
Wasps are a big problem in this area of the world, and I've tried all sorts of things. On one occasion, while I was gas welding, I dropped a red-hot piece of metal on the ground & disturbed a huge ground-wasp nest. They came swarming out of the ground, and I thought I was in big trouble...then remembered I was holding an oxyacetylene cutting torch in my hand. It worked (they go off in the air like popcorn!), but I had to stand there for a long time.
To get rid of them, do it at night, when it's coldest. They should all be in the nest then, and they won't come out at all if it's really chilly. I use the long-range cans (brand doesn't seem to matter, as long as it's for wasps), and really soak the whole nest & make your withdrawal. You should hear a little humming from the nest for 2-3 minutes, then nothing at all. Ever.
http://www.freewebs.com/zetec7/
focijohn
posted on 14/8/08 at 07:13 PM Reply With Quote
the spray foam works well, gets them really really pi**ed off so make sure u can move off sharpish.
Anyone going slower than you is an idiot. Anyone going faster than you is a maniac.
Too many targets but too few bullets.
DarrenW
posted on 14/8/08 at 07:19 PM Reply With Quote
When you say in the roof do you mean in a roof void and difficult to get too or in plain view?
Long range wasp stuff gets my vote. However for an organic idea what about taking stuff out of garage to empty it a bit, take BBQ inside, light and close doors. Maybe some extra smokey stuff on it too for good measure. Just nothing that will give big flames etc for obvious reasons. Never tried it myself though. Might give garage an interesting aroma for a while.
splitrivet
posted on 14/8/08 at 10:45 PM Reply With Quote
Arrived at the house in France last year to find we had hornets in the chimney these varmints are about 2 inches long (I aint kidding) a few of em tried to fly off with the wife unfortunately they only made it to the front door.
Bob
saigonij
posted on 15/8/08 at 07:15 AM Reply With Quote
Mr Muscle oven cleaner - really p*sses them off!
posted on 15/8/08 at 07:52 AM Reply With Quote
I like to sneak up behing them like a ninja and the karate chop them to death.
Benzine
posted on 15/8/08 at 08:22 AM Reply With Quote
When I find a wasps nest I capture and harness the wasps to make a BEC. They make the same noise and power
DarrenW
posted on 15/8/08 at 08:26 AM Reply With Quote
LMAO Brilliant.
I find a cheaper bin bag gives best result though. Rubble sacks muffle the sound too much.
I remember when i was an apprentice that one of the lads was given an old terminated nest so he could get the grubs out, apparently good fishing bait. Not sure about the white cyanide type stuff that was used to kill them though. When he broke the nest open in the workshop there were still some live ones in the middle albeit they werent exactly highly active.
