saigonij
posted on 15/8/08 at 07:32 AM |
Wheel Arch Liners
Even going slowly up and down the road causes stones to be thrown up in side the rear arches, so i imagine at higher road speeds there might be the
possibility of damage?
So i want to line the inside with some sort of material. First choice was rubber - maybe 4 - 6mm thick.
What would be other peoples thoughts?
westf27
posted on 15/8/08 at 07:36 AM |
dont go slowly then!
Thick poly body sealer or plastic spiky door mat would help to reduce the impact
Humbug
posted on 15/8/08 at 08:01 AM |
Laminated flooring underlay foam. It's about 5mm thick and very light
saigonij
posted on 15/8/08 at 08:14 AM |
oh - i like the under floor foam idea - can get it from b&Q i guess too?
myke pocock
posted on 15/8/08 at 08:32 AM |
I have painted my wheel arches with a thick rubber solution that is used on roofs for waterproofing. It came from B & Q and I cannot remember the
name of it as I am at work. It is not a B & Q own brand though. Two coats gives a nice thick layer but I have not driven my car yet so cannot
comment on whether it does the job but it looks OK to me.
DarrenW
posted on 15/8/08 at 08:50 AM |
Not a bad idea but the stuff ive used comes in big rolls and therefore costs a bit.
What about thin rubber mat used for flooring, ive seen smaller bits for sale at the shows before.
I didnt use anything and not suffered any ill effects.
posted on 15/8/08 at 09:20 AM |
3k miles at many speeds over many road surfaces and no problems with my arches front or rear.
Once you get going you can't here anything anyway
saigonij
posted on 15/8/08 at 10:47 AM |
ok, maybe im worrying too much then...
