Author: Subject: diesel injector cleaner
posted on 19/8/08 at 06:42 PM Reply With Quote
my old van broke due to the injectors clogging up, but now my new van has broken too! So i need to get the old one working in time for the morning!
Any good reason why i shouldnt bang in an overdose of injector cleaner?! It says half a bottle to 50L of fuel, im thinking 2 bottles to 10L of fuel?! I figure there isnt much to lose, unless its definately a bad idea!
posted on 19/8/08 at 06:48 PM Reply With Quote
You have nothing to lose but does the engine run at all? cos if not then I think you will be wasting your time . If the engine doesn't fire up give it a squirt of brake cleaner into the inlet, it works as well as easistart and diesels don't seem to get addicted to it like they do with easistart
posted on 19/8/08 at 06:59 PM Reply With Quote
nah, it starts fine. When it packed up i managed to drive home by avoiding full boost. Conversely, the vivaro has a turbo that siezes if you DONT keep it at full boost! Cheers!
adithorp
posted on 19/8/08 at 07:16 PM Reply With Quote
At work we use Forte diesel conditioner and get really good results. We fill a new fuel filter with it, put any remaining in the tank and start up. Had cars that wouldn't tick over or rev cleanly pick up one cylinder at a time and run perfect within seconds of starting.
Forte's not available through the after-market though. Cant see why you can't do the same with others though.
adrian
http://jpsc.org.uk/forum/
posted on 19/8/08 at 07:21 PM Reply With Quote
ive got to do 130 miles in total tomorrow, the vivaro used 6 litres of oil to go 250 miles today, and the turbo was cutting out this evening. The sprinter is definately on its last legs, but its a much tougher van. I just cant decide which to take. Sprinter let me down before. I also have no time to get either fixed properly all week! What a choice to make
If the injector cleaner works then the sprinter should be good. Gonna take it for a blast and see what happens!
Just thinking out loud, ignore me!
posted on 19/8/08 at 09:07 PM Reply With Quote
well it seems to have worked, just a shame theres nowt really left on first gear and the damned handbrake sticks
*note to self, work harder next year and get a better van.
adithorp
posted on 19/8/08 at 09:15 PM Reply With Quote
Handbrake sticking will be the adjuster/lever where the single front handbrake cable joins to the rear section. Get undernethun the drivers side just in front of the rear axle and put some easing oil on. It'll free off in no time with a bit of working about.
adrian
posted on 19/8/08 at 09:22 PM Reply With Quote
cheers
posted on 20/8/08 at 04:52 PM Reply With Quote
adrian, thanks for that. You were spot on with the handbrake
I made it
