Author: Subject: Changing diesel fuel filter on 2.0 tdci
piddy
posted on 21/8/08 at 03:58 PM Reply With Quote
Just changed the fuel filter on my Mondeo diesel. Now it won't start.
Do you have to do any thing like purge the air out? or fill it with diesel?
whitestu
posted on 21/8/08 at 04:00 PM Reply With Quote
I didn't when I changed the on on my Citroen C8, but obviously a different engine.
Stu
Danozeman
posted on 21/8/08 at 04:27 PM Reply With Quote
Theyr a b*****d if you dont fill the filter with diesel first as they wont pull the air through. You need to take the filter off and try to fill it with diesel. Failing that try and borrow a priming pump from someone to pull it through that way. Theyr a right pain as they have no lift pump from the tank.
You could turn it over and over and it might fire up in the end but i wouldnt advise it as the pump is running dry.
[Edited on 21/8/08 by Danozeman]
Dan
piddy
posted on 21/8/08 at 04:31 PM Reply With Quote
alll sorted now.
filed it and off she went
