mr henderson
| posted on 2/9/08 at 04:07 PM |
Putting the front subframe back on an MGB?
Actually it's an NG TC that I'm attempting to put it on, but very much the same principle.
The basic problem is that I can't get to the front bolts that have dropped inside the hollow subframe without taking the front springs off, and
it would seem that a special spring copmpressor is required for that (which I don't have).
If there is a trick to this I really would like to know about it
TIA
John
r1_pete
| posted on 2/9/08 at 04:18 PM |
Common problem, basically, without a spring compressor you need to assemble the cross member on the car:
1. Fit the double ended bolts to the car, they are a tapered fit into the chassis, and tighten the top nuts.
2. Fit rubber pad to each point on the cross member, locating collar downwards.
3. Jack cross member into place.
4 Ruber isolator bush, followed by the small steel plate on each bolt, followed by the nuts.
You access the front mounting nuts via the area where the spring is, there are holes below but they dont line up and many a socket UJ has been lost in
there. If you dont do the job in that order the crossmember can end up missaligned, and the wrong pressure on the rubbers due to the tapers not being
set right - the Mark Evans MGB rebuild shows the incorrect method being used.
Re-assemble everything, you can now use the cars weight to compress the springs.
[Edited on 2/9/08 by r1_pete]
mr henderson
| posted on 2/9/08 at 04:26 PM |
Somehow you can just tell when someone really knows about something. Just a feeling that one gets.
Now I need to locate the correct spring compressor. Haven't found anything on Ebay so I'm trying google
John
Bigheppy
| posted on 2/9/08 at 05:40 PM |
On the program an MGB is reborn mark evans made a spring compressor from an old steering rack.
r1_pete
| posted on 2/9/08 at 06:25 PM |
Fraid so John, my current Zetec B must be the 10th Ive done, ans always started with a bare crossmember.
You could mock the crossmember onto the car, then use its weight to remove the springs, fit it properly then rebuild.
| posted on 2/9/08 at 08:30 PM |
Yep trolley jack under the spring pan thats the way we used when changing MGB wishbone bushes and springs --- wouldn't have been too tough to
make a spring compressor up from threaded bar.
| posted on 2/9/08 at 08:31 PM |
mr henderson
| posted on 2/9/08 at 08:49 PM |
So is it best to undo the nuts and bolts on the spring pan, or the one at the bottom of the upright?
John
r1_pete
| posted on 3/9/08 at 07:23 AM |
Remove the bolt at the top of the king pin, the one which secures it to the lever arm damper, the kingpin will swing down out of the way.
That way its easier to re-assemble, you have the in and out movement on the pin, and up and down on the shock to line the bolt back up.
Rgds.
Pete.
:{THC}:YosamiteSam
| posted on 4/9/08 at 11:22 PM |
that was on today - he used a long 14mm bolt and few welded on bits to wind spring in.. or he said use the weight of the car to compress it if on the
car using the jack
he did mention about the bolts too
mr henderson
| posted on 5/9/08 at 07:03 AM |
All done now, thanks, chaps.
John
