liam.mccaffrey
| posted on 2/9/08 at 06:58 PM |
Cloudy headlights
my headlights on my mini-van type effort thingy-me-bob have gone really cloudy and are dimming the lights significantly
I priced up what i can only assume were new solid gold ones from the motor factors
does anyone thinck i will be able to polish the clouds off with a mop and some cutting compound or something. they are plastic btw
[Edited on 2/9/08 by liam.mccaffrey]
Build Blog
Build Photo Album
COREdevelopments
| posted on 2/9/08 at 07:39 PM |
i tried that out on a yaris, came up ok and worked better. so why not give it a try.
rob
Mark Allanson
| posted on 2/9/08 at 07:54 PM |
We repair lightly scratched headlamps at work by flatting with 1000 and then 2000 and then G3 on a polishing mop, works a treat
zetec7
| posted on 3/9/08 at 04:58 AM |
I've used 1000-grit wet sanding, followed by a commercial plastic polish, with great success. If you're careful, it will come out clear
as glass.
http://www.freewebs.com/zetec7/
melly-g
| posted on 3/9/08 at 06:55 AM |
Use toothpaste!! this works ok, mate done it on a vitara good as new now.
| posted on 3/9/08 at 10:56 AM |
Second the toothpaste. Fairly gentle so you'll struggle to make things worse (which could be easy with stronger abrasive pastes)...
