andy o
| posted on 4/9/08 at 06:14 PM |
any moped experts?
sons yamaha aerox refuses to start.new plug and cap/clean fuel and oil.
seems to be blowing back thru carb
anyone got any ideas?
thanks andy
jambojeef
| posted on 4/9/08 at 06:31 PM |
At risk of blaspheming in my religion by keeping another one of the evil noisy contraptions on the road....
Either the reed valve will be at fault or the pipe that carries the charge to the combustion chamber.
My apologies if you're familiar with 2 strokes but behind the carb is a reed block and reed valve (very thin spring steel) all bolted
together.
When the piston moves towards TDC it draws the mixture into the crankcase against the springiness of the reed valve. When moving away from TDC the
increased pressure in the crankcase shuts the reed valve and forces the mixture through a little bypass pipe (or sometimes channel cast into the
block) and into the combustion chamber.
Have a look at the reed valve and block first to check that the valve isnt loose or distorted and seats ok on the block. If that looks ok, find the
the charge pipe / channel.
Years ago on an old outboard motor the fault was that the charge pipe had come loose from the cylinder wall and the mixture was basically venting to
air.
Hope that helps
Geoff
andy o
| posted on 4/9/08 at 06:37 PM |
thanks,will have a look that
Triton
| posted on 4/9/08 at 06:47 PM |
Sounds like you need to take the head off and decoke it, reeds may be broken but doubt it does it feel like there is any compression? strokers pop for
a past time but beats a 4 stroke any day...it's all about the noise and smell don't yer know....
www.tritonraceseats.com
www.hairyhedgehog.com
owelly
| posted on 4/9/08 at 07:17 PM |
Is there a spark? And is it in the right place?
The flywheel could have slipped on the end of the crank and sheared the woodruff key.
If it is sparking, is the plug wet with petrol?
http://www.ppcmag.co.uk
andy o
| posted on 4/9/08 at 07:21 PM |
have a strong spark ,it's trying to fire but even spraying petrol thru carb's not working,it seems to blow it back thru carb!
motorcycle_mayhem
| posted on 4/9/08 at 08:50 PM |
Reed valve, reed valve, reed valve.
One/all of the metal strips won't be seating, dirty, or are bent. Maybe the reed block isn't seating
Reeds are critical, I remember the difference Boysen reeds made on my RD250LC.... spent 6 months in hospital after I'd fitted them though (age
17, L plates, immortality, invicibility vs bus shelter).
Always giggle when I think of a Gamma lump going in the Westfield....
owelly
| posted on 5/9/08 at 10:07 AM |
I had an RG500 and a pocket full of spark plugs........
