eccsmk
| posted on 5/9/08 at 05:55 PM |
vauxhall combo
ive just got a combo and everytime you close a door it instantly locks its self anyone know how to stop this??
its a 2003 model
thank you
CRAIGR
| posted on 5/9/08 at 06:16 PM |
Leave the door open !!!
Sorry
| posted on 5/9/08 at 06:59 PM |
My daughter's Corsa does the same and while it does annoy me she got used to it and doesn't mind.
novacaine
| posted on 5/9/08 at 07:20 PM |
keeps the thieving scum at bay
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but
your older, shorter of breath and one day closer to death
novacaine
| posted on 5/9/08 at 07:21 PM |
but if you really want rid of it you could disconnect the switch that detects when the door is open
downside of this is that you are more than likely to get a warning light that a door is open
adithorp
| posted on 5/9/08 at 08:03 PM |
I assume its not got central locking. The usual cause is a broken detent spring in the door catch/lock mechanism. usually needs a new catch unless you
can find a spring (tiny).
adrian
http://jpsc.org.uk/forum/
eccsmk
| posted on 5/9/08 at 08:08 PM |
it has got central locking and i think itll be a case of disconnecting the wires from the drivers door lock making it manual locking
never mind thanks folks
phoenix70
| posted on 5/9/08 at 08:46 PM |
don't know about the combo, but some car have that as a security feature, it can normally be turn on or off, have a look in your manual, it may
tell you how to switch it off in there (Or go and see vauxhall and ask them)
bob tatt
| posted on 6/9/08 at 07:08 AM |
used to have these from new at the firm i worked at vauxhall never told us about this feature got locked out of my van several times never happened
after we had them back for the first service dont know what they did but they all stoped locking auto pain in the arse
eccsmk
| posted on 6/9/08 at 08:50 AM |
i now know why all posties keep their doors open.
thanks for the info folks ill get in touch with vauxhall monday
