Author: Subject: My new little runaround won't start :(
eznfrank
posted on 10/9/08 at 09:14 PM Reply With Quote
You may recall I posted last week about a timing belt failure on my tintop Alfa 147. Well becasue it was going to be £1900 from the main stealer and even local bods wanting over £1500 I decided to do it myself.....anyway, in the mean time I bought a little Fiat Cinquecento from the auction to run around in. Well tonight it won't start and has been abandoned in the work carpark.
I'm after suggestions as to what to do/look for? Mainly because I'm going to have to try sort it out in a limited time frame tomorrow lunch time......and in my suit
Anyway, there appears to be fuel getting in as it flooded after the 2nd attempt so I took the air box apart to help the vapours out a bit, and it was trying to start and the battery is new and was also recently charged. I did manage to bump start it and held the revs for a couple of minutes but it just didn't want to hold at idle??
I reckon it's probably just the spark so was going to take a bit of sandpaper to run through the contacts, and maybe a few basic tools to see what I can do, but if anyone has any ideas that would save me masses of time that would be greatly apreciated???
novacaine
posted on 10/9/08 at 09:17 PM Reply With Quote
put a V8 in it
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
Macbeast
posted on 10/9/08 at 09:23 PM Reply With Quote
Could be the timing belt ?
eznfrank
posted on 10/9/08 at 09:24 PM Reply With Quote
Originally posted by novacaine
put a V8 in it
In my lunch hour?!?!.....and in my suit?!?!
Any serious suggestions?
MikeR
posted on 10/9/08 at 09:40 PM Reply With Quote
call the AA, they get high percent of cars going again, if not they'll get it home so you can work on it properly.
otherwise, buy another small car
Simon
posted on 10/9/08 at 09:42 PM Reply With Quote
^^ What he said. 40 Quid would be well spent.
Simon
eznfrank
posted on 10/9/08 at 09:47 PM Reply With Quote
Yeah I actually have cover but couldn't really be bothered hanging round for them again (2nd week running!!) tonight.
The only problem is that the car is 3 stories underground??
posted on 10/9/08 at 10:39 PM Reply With Quote
After problems experienced with one Italian car - he goes and buys another... are you totally bonkers??
Serves you right... get a proper car!
Sorry I cant help you...
whitestu
posted on 11/9/08 at 07:55 AM Reply With Quote
Of course he is, but the important thing is he's bonkers with style!
I'm with Clarkson on this one - you can't be a real petrolhead unless you've owned Alfa's
Stu
eznfrank
posted on 11/9/08 at 08:04 AM Reply With Quote
Stu
Yeah 2 Alfa's, a Fiat, an Italian wife and now the Indy to add to my woes!!!!!!!!!!!!!!!!!! - glutton for punishment!!!
Breakdown people on the way now so will let them sort it, it'll be electrics I guarantee it!
[Edited on 11/9/08 by eznfrank]
ashg
posted on 11/9/08 at 08:11 AM Reply With Quote
cinqs have a habbit of the crank position sensors going intermitant meaning sometimes they start sometimes they dont. take the air box off and when turning it over if it backfires out the injection manifold that will be your problem.
done lots of work on cinqs and italian metal in general lol.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
eznfrank
posted on 11/9/08 at 08:15 AM Reply With Quote
That seems to make sense. I took the plugs out this morning and gave them a bit of a clean with no real difference noticed and then took the top off the airbox and it did exactly that. Is it a big problem to sort?
grazzledazzle
posted on 11/9/08 at 09:10 AM Reply With Quote
And don't forgot, you will need to
Fix It Again Tomorrow
Hope that's been of use.
[Edited on 11/9/08 by grazzledazzle]
ashg
posted on 11/9/08 at 12:50 PM Reply With Quote
you just need a new crank position sensor. quite easy to access can be purchased from the likes of partco etc.
you virtually have to destroy the old one to get it out then sand the hole with a bit of emry cloth to clean it up then put a little bit of copper grease (if you have some) on the new one to fit it then put the little 10mm bolt back and connect the plug.
eznfrank
posted on 11/9/08 at 12:56 PM Reply With Quote
Cheers mate, I've actually ordered one now, £22.
posted on 11/9/08 at 01:13 PM Reply With Quote
the crank sensor on my volvo died recently - AA man disconected battery so that the sensor was not powered so any magnetic bits would drop off.
sounds like a good theory but did not work.
maybe worth a try although don't hold your breath.
Simon
posted on 11/9/08 at 07:17 PM Reply With Quote
Stu
Cool, I'm a proper petrolhead.
Bought a Sud for fifty quid for resto, bit of further investigation revealed most of bulkhead was missing so scrapped it.
Did at least 5 miles in it.
Still, at least I've owned an Alfa
Simon
eznfrank
posted on 11/9/08 at 07:23 PM Reply With Quote
Stu
Simon
I'm not sure if it has to be Alfa"s" plural to be a true petrol head? I love pretty much all of them for looks and noise etc but they are a bit of a pain in the sh1tbox!!!
eznfrank
posted on 12/9/08 at 07:37 PM Reply With Quote
Huge thanks to ashg for a spot on diagnosis, problem now solved and back on the road. Not sure the recovery company would be so pleased if they found out a £20 part and 10 mins labour on a £350 car led to a bill for hundreds for specialist recovery to drag it out of the underground carpark!
The missus is over the moon her little cinq is back on the road though, reckon i might be on for a bit tonight
[Edited on 12/9/08 by eznfrank]
t.j.
posted on 13/9/08 at 05:39 AM Reply With Quote
hmmmm, my missus need more to make her happy
andrew.carwithen
posted on 13/9/08 at 07:03 AM Reply With Quote
Stu
I'm on my second Alfa too...
Recently sold the 156 and bought a Spider instead. I did enjoy the 156 but I absolutely love the Spider. I'm always looking for excuses to 'pop out to the shops'
'Wassat luv?...Running low on milk?...No problem, I'll get that for you straightaway...'
Problem is, a trip to the garage just up the road turns into a 20 mile round trip!!
You buy an Alfa with your heart- not your head. Don't think I could go back to a standard eurobox now...
eznfrank
posted on 13/9/08 at 07:41 AM Reply With Quote
They can be a bit of a pain in the ass but Alfa's are pretty cool.
ONly problem is missus wants to get rid of teh 145 and get a Lancia Delta Evo instead - which i envisage being the biggest headache ever!!!!
