AndyGT
| posted on 21/9/08 at 05:55 PM |
another problematic tintop
Last few weeks Opel Corsa has been getting nosier and nosier like a wheel bearing. It was louder on LH turns than right so began to change the right
wheel bearings. On stripdown the bearings were in pretty good shape and I suspected I was doing the job for nothing!!
Anyway, the car is back together and still making the same noises. I don't want to do the other side cos I think they'll be OK.
I'm thinking that the diff bearing are shot!! Does this sound right?
Thanks in advance....
nothing is impossible
everything is possible
big_wasa
| posted on 21/9/08 at 05:59 PM |
More like the cv joints on the drive shaft.
AndyGT
| posted on 21/9/08 at 06:15 PM |
I started to think CVs too as one of the boots was split and I replaced the boot. It's not clunking on turns which then made me think the diff
bearings due to diff effect on the bends...
Danozeman
| posted on 21/9/08 at 08:00 PM |
Diff bearings are quite common on corsa boxes. Esp if the cars had a hard life.
Dan
