the moa
posted on 8/1/04 at 01:01 AM |
Bike powered Leugo locost
Hi there can any one help in making my dicision in chosing an engine.
Been looking at the bike engines and i like the idea of them but with not knowing much about them and having more knowledge availible about pintos
crossflows i was swaying more towards them.
can anyone point in the right direction in reading up what info i would need if considering a bike engine e.g engine positioning weight balanceing
etc, and whether or not it would be a problem being a live axle.
i have looked at various sites re the westfields but cant seem to get much info.
any help much appreiciated.
ChrisW
posted on 8/1/04 at 09:56 AM |
Certainly the live axle isn't a problem. Lots of people have done it, Jasper being the first that comes to mind and I suspect the Isonblade is
live axle too. Don't know about the other questions tho. I'm sure Luego can help - give Grant a ring!
Chris
My gaff my rules
cosworth
posted on 11/1/04 at 09:05 PM |
You will have no problems using a bike engine with a live axle. Position the engine so that the drive from the output flange on the engines lines up
with the axle flange and as far back in the chassis as possible.
James
posted on 12/1/04 at 01:09 PM |
Actually, I'd be careful with putting it too far back.
Im pretty sure both Jasper and Jon Ison regretted putting the engine back as far as they did.
I have no dimensions to guide you though!
Moa,
If you're buying a Luego then do they do a car with Live Axle still?
Anyway, if you're buying a chassis then the manufacturer will supply you a cradle (assuming a common engine type) to fit the bike engine so you
won't need to worry about positioning etc. will you?
HTH,
James
Findlay234
posted on 12/1/04 at 05:19 PM |
why do they regret putting it so far back?
posted on 12/1/04 at 07:35 PM |
Is it because they ended up sitting on it? . If it's a question of weight distribution I haven't heard anyone saying they have a
problem.
yours, Pete.
the moa
posted on 13/1/04 at 10:38 PM |
Hi there thanks for info i haven't yet spoke to Luego yet but will call them and see if i can get a better idea of costs and difficulty
level.....
have been speaking to someone who currently has a kit with a car engine and is thinking of converting over the summer and he is getting a someone to
help him with like a masters deagree in engineering and being that this is one our first projects im not sure whether would be do-able. So will
wait and see what Luego say and go from there .
StuartA
posted on 14/1/04 at 12:10 PM |
As far as I know Luego do not make a cradle for any bike engines to go in the Live Axle chassis. This is exactly the build that we are attempting. We
are due to have someone weld a cradle for us, hopefully in the very near future.
No problems with the dimensions, the bike engine (Fireblade) is much smaller than any equivalent car engine, so no problem with it fitting the
chassis. We have put ours as far back as is practical, if you sit it too far forward you may have problems with exhaust fouling the chassis rails.
Jamesfear
posted on 17/1/04 at 06:18 PM |
there is one being made at luego right now. Give them a ring and they will help you.
spalding clubgti host
the moa
posted on 23/1/04 at 11:09 PM |
hi there,
decided to go for a pinto in the end, i was being a bit adventureous perhaps next year. thanks for all the help and advice.
