Author: Subject: Is this CV boot clip any good?
Mansfield
posted on 11/10/08 at 09:05 AM Reply With Quote
I have just bought a CV Joint kit to do SWMBOs Tigra, and it came with these clips.
I have not seen them before, are they any good?
I guess I pull it tight, fold it back over and push the tags in before cutting of the excess metal. I cant quite decide which way round to put it, probably folded over bit pointing to back of car.
If anyone has fitted one of these, do they last?
[Edited on 11/10/08 by Mansfield]
theconrodkid
posted on 11/10/08 at 09:10 AM Reply With Quote
you need a special tool to put them on,just use a cable tie and sell that to someone who wants to lad their exhaust
who cares who wins
pass the pork pies
Mansfield
posted on 11/10/08 at 09:11 AM Reply With Quote
I was planning a pair of pliers!
theconrodkid
posted on 11/10/08 at 09:16 AM Reply With Quote
you wont get it tight enough with pliers...believe me thats why i bought the tool
who cares who wins
pass the pork pies
Mansfield
posted on 11/10/08 at 09:24 AM Reply With Quote
I see what you mean.
http://www.amazon.com/dp/B000XQ2VP8?smid=A2IY3YALOGHWI&tag=nextag-tools-tier4-delta-20&linkCode=asn
Off to GM to get some proper ones I think.
omega0684
posted on 11/10/08 at 09:36 AM Reply With Quote
mate just use jubalee clips
theconrodkid
posted on 11/10/08 at 09:46 AM Reply With Quote
jubs are heavy and will cause balance probs,stick to cable ties
who cares who wins
pass the pork pies
Mansfield
posted on 11/10/08 at 10:15 AM Reply With Quote
I bought the tool instead, looks like some medical instrument, wish me luck.
Thanks for your help.
posted on 11/10/08 at 11:27 AM Reply With Quote
Jubilee clips often catch on the upright and come straight off .
theconrodkid
posted on 11/10/08 at 12:16 PM Reply With Quote
if its anything like mine,have a play and read the destructions first(i know its not a man thing to read instruction but you need to in this case)
who cares who wins
pass the pork pies
bob
posted on 11/10/08 at 12:50 PM Reply With Quote
Its best to use the correct type if using cable ties, you need the ones that feed in from the end and not the side like the popular ones.
Mansfield
posted on 11/10/08 at 05:11 PM Reply With Quote
The tool worked quite well, looks quite a neat job.
The old ones (10 years and 100,000 miles) were doing a good job, the grease was liquid and there wasn't the slightest sign of a leak. The liquid grease spilt into my screwdriver box once I pulled the gaitor back to see the circlip. That took some cleaning up, but better than going on the drive I suppose.
I have had nothing but trouble from cable ties and wont use them again, although I haven't seen a type different to the 'normal' ones.
Thanks for all your help.
