speedyxjs
| posted on 15/10/08 at 02:40 PM |
Wishbone brackets
I need to fit my wishbone brackets but im a bit scared.
Obviously they need to be acurate but im a bit stuck on how to do it. I cant make a frame as in the book because i have no way if cutting holes big
enough to fit the bolts through.
Also does it matter if the wishbones are at a slight angle ie, the distance between the front brackets on the front wishbone are less than the rear
brackets on the front wishbone?
Mr Whippy
| posted on 15/10/08 at 02:44 PM |
you can buy them pre-made and drilled, though yours will probably have to be castings...hee hee hee
mighty me...is there nothing I can't find on the web in seconds!? I should change my job to be a professional web browser
linkydoo
[Edited on 15/10/08 by Mr Whippy]
mr henderson
| posted on 15/10/08 at 02:58 PM |
I think you should be downright terrified!
Alternatively you might just be mildly concerned to get it as right as possible the first time, and to not have to redo stuff more than is moderately
necessary.
Just do the best you can, you'll soon be able to see if you need to redo anything.
I don't follow the bit about "because i have no way if cutting holes big enough to fit the bolts through. "
And how much of an angle are we talking about here?
John
maartenromijn
| posted on 15/10/08 at 03:01 PM |
I do not understand what mean that you cannot drill holes big enough...
I don't quite understand the angle querie either.
Maybe this is of any help to you:
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=Afb068klein.jpg
BLOG: http://thunderroad-super7.blogspot.com/
Mr Whippy
| posted on 15/10/08 at 03:16 PM |
why aren't you simply marking out the bracket locations from the chassis itself? pick a couple of center line points and measure from them
either side. your problem isn't all that clear tbh
James
| posted on 15/10/08 at 03:31 PM |
quote: Originally posted by Mr Whippy
it's cos he's using M80 bolts due to the weight of his car, wishbones are like a meter across
Speedy,
Don't understand your question!
But if you build a jig like the one listed above, or the one in my photo archive, then it's really easy to place the brackets.
http://www.locostbuilders.co.uk/photos.php?action=gal&user=James&folder=Bracket%20Jig
HTH,
James
- Muhammad Ali
speedyxjs
| posted on 16/10/08 at 06:45 AM |
^^^ Thats what i mean. I cant build a jig like that because the bolts are too big. I already have the brackets made. I just need to get them in the
right place.
mr henderson
| posted on 16/10/08 at 06:53 AM |
right place.
That's a repetition. What we are waiting for is an explanation
John
James
| posted on 19/10/08 at 07:01 PM |
Bump!
Come on Speedy.... explain all?
Again, bolts are too big...?
Are they 25mm diameter bolts or summat? Even then I would've thought you could get tube that would go through the bracket holes!
Tell all!
James
- Muhammad Ali
NigeEss
| posted on 19/10/08 at 10:09 PM |
I thought you were
