nitram38
| posted on 21/10/08 at 08:24 PM |
OT: wanted, 17th edition multi-tester
Any sparks out there know where I can get a good tester which covers all of the 17th edition 2391 tests?
I have looked at lots, but I am looking for an all in one jobbie that does all the tests.
Oh, and as cheap as possible!
ozzieboy
| posted on 21/10/08 at 08:46 PM |
17th tester
Hello ,
Im a sparks and have a fluke 1652 multi function tester, it a nice unit but the crap thing with it is you have to null the leads each time you change
from the 13amp plug to test leads. My mate from work have the megga all in one multi function which i rate highly it even has blue tooth and you dont
have to press the test button, as it does this auto on earth loop which is handy. Also you dont need to null the leads as both are the same value!
Might be worth a look on flee bay? Or try and screw a holesaler down to the ground with credit crunch plea!
IF ITS NOT BROKEN DON'T FIX IT....
nitram38
| posted on 21/10/08 at 09:11 PM |
Which megga one?
| posted on 21/10/08 at 09:13 PM |
i use an alphatek metrel easitest, not the latest version, but i cant think of any test required under 17th that wasnt already in 16th?
forgot to say, it was £450
[Edited on 21/10/08 by JoelP]
nitram38
| posted on 21/10/08 at 09:15 PM |
Just found the megger MFT1553.
The metrel looks good too
maximill666
| posted on 21/10/08 at 09:19 PM |
Verification of phase sequence was not a requirement of the 16th edition but it is in the 17th!
Obviously only applicable to 3 line (Phase) installations.
| posted on 22/10/08 at 06:21 AM |
that explains it, im domestic!
nitram38
| posted on 22/10/08 at 07:07 AM |
The new metrel includes phase rotation.....
nitram38
| posted on 22/10/08 at 10:48 AM |
Just ordered a Megger MFT 1553 on ebay for £429.
It includes a bluetooth link and software to print out my own certs
ozzieboy what device does your mate bluetooth it too?
I am wondering if a smartphone is anygood for the job or is it better using a laptop?
[Edited on 22/10/2008 by nitram38]
