Author: Subject: her Corsa's dieing!
Mr Whippy
posted on 24/10/08 at 11:31 AM Reply With Quote
her Corsa's dieing!
Miss Whippys corsa is going tits up at work, getting e-mails
all the gauges have stopped working including the speedo, radio, fuel gauge & tacho she checked the fuses but none have blown so I suspect a bad earth is the cause. Even the heater motor is running slower
its a corsa-B diesel, anyone come across this before with these little buckets??
speedyxjs
posted on 24/10/08 at 11:33 AM Reply With Quote
Thats one clever corsa
posted on 24/10/08 at 11:35 AM Reply With Quote
Battery failed?
Battery earth strap / power lead connectors need a clean and tighten?
(but I'm sure you know all the non-Corsa-specific stuff anyway!)
[Edited on 24/10/08 by David Jenkins]
Danozeman
posted on 24/10/08 at 11:38 AM Reply With Quote
Plug behind the clocks? This is a prob on the corsa-c's and im sure the later b's did it aswell.
Dan
r1_pete
posted on 24/10/08 at 11:43 AM Reply With Quote
Its just saying its time for daddy to build or buy her a new car...
Mr Whippy
posted on 24/10/08 at 11:48 AM Reply With Quote
oh thanks, wasn't aware of that
car runs fine and the battery light is out, just no gauges, she might be imagining the motor speed, I haven't heard it myself yet
cheers
don't think she trusts me to do that...she'd just ask what's going to fall off it then?!
[Edited on 24/10/08 by Mr Whippy]
maartenromijn
posted on 24/10/08 at 11:53 AM Reply With Quote
I have had the same problem with a Merc 250TD. All electrics on board were dead.
Turned out that there was a short circuit in the ignition switch and/or the rectifier was broken.
Check whether it still charges.
BLOG: http://thunderroad-super7.blogspot.com/
cjtheman
posted on 24/10/08 at 12:20 PM Reply With Quote
hi
just had this done myself on the misses car as Danozeman said way to find out when it happens again push on the clocks
cheers
colin
posted on 24/10/08 at 12:21 PM Reply With Quote
Modern hi-tech batteries tend to die very suddely and very completely -- if nothing obvious you need to do all battery voltage tests.
Mr Whippy
posted on 24/10/08 at 12:33 PM Reply With Quote
thanks guys, certainly know where to start looking now cheers.
MikeR
posted on 24/10/08 at 02:51 PM Reply With Quote
sounds like when teh speedo cable stops working. its an anti theft system - no speedo, no clocks etc.
happened to a mate on a first gen corsa twice in a couple of months, really pee'd him off.
mistergrumpy
posted on 24/10/08 at 04:24 PM Reply With Quote
Happens to my Corsa on occasions. I just switch the engine off and restart it and it's all fine again.
bob tatt
posted on 24/10/08 at 05:30 PM Reply With Quote
push on the dash just behind the clocks my wifes died a couple of years ago aa man said its a common problem on the corsas the next time it did it wifey sorted it hope this helps
