Author: Subject: OT - window trickle vent fitting
posted on 24/10/08 at 09:51 PM Reply With Quote
Any builders or window fitters about?
We had uPVC windows fitted 2-3 years back and at the time only the bathroom window was fitted with a trickle vent.
I'd like to have vents on the bedroom windows (and possibly all the windows).
Looking at the one on the bathroom window it seems as simple as drilling a few holes in the frame (avoiding the glass) and fitting something like this...
http://www.reddiseals.com/acatalog/window_hardware_trickle_vents_sl otted.html
Can anyone see any problems or advise on what size of vent should be fitted?
Nick
LBMEFM
posted on 25/10/08 at 07:05 AM Reply With Quote
I carry out property maintenance and I often fit them to plastic and wooden windows. I usually router out a slot before I fit the window, as it's sometimes difficult in situ due to the lack of space. By all means drill a series of holes then clean them up with saw. Size wise it depends on the size of the window but they are normally about 350mm long. If in doubt ask a local double glazing firm they can give you advice and supply the correct bits.
posted on 25/10/08 at 08:20 AM Reply With Quote
Do the windows open? You should fit them in the main outer frame not the inner opening sections but it is just a matter of making holes and fitting the vent. There may be some steel reinforcing inside the box section depending on the window specs. They are noisy in direct wind.
[Edited on 25/10/08 by Peteff]
posted on 25/10/08 at 08:23 PM Reply With Quote
Cheers Guys - 400mm vents ordered and drill being sharpened.
Pete - no space in frame so will have to go in window as per existing bathroom window.
Now have to make sure I don't hit the glass...!
