omega 24 v6
| posted on 29/10/08 at 11:21 PM |
Any one got access to a clio parts database?
As the title really. I want to know whether the front o2 sensor and rear o2 sensor are the same part number. I think I may need one but don't
want to buy 2 if they are 1 and the same.
Oops should add it's a 1.2 petrol O3 plate with the df4 (think thats right from memory) engine.
[Edited on 29/10/08 by omega 24 v6]
prawnabie
| posted on 29/10/08 at 11:30 PM |
Hi
Yes mate they are the same. I work at renault so can get you one at cost if you can wait for tomorrow for a price.
davie h
| posted on 29/10/08 at 11:51 PM |
sorry for the hijack
Prawnabie
i have a 03 megane and went through a puddle and the electrics went mad wipers going constan etct. i traced the fault to a module on the right next to
the battery i took it out and dryed it out all seemed ok after that but now the battery is going flat but not all the time have you seen this problem
before or is it time to trade it in
cheers Davie
quote: Originally posted by prawnabie
Hi
http://www.flickr.com/photos/24179682@N04/?saved=1
| posted on 30/10/08 at 07:51 AM |
Check the Ggendan list http://www.gendan.co.uk/oxygen_lambda_sensors_Renault_Clio.html
Usually both sensors are the same type but may have different lead lengths and plugs.
Downstream O2 sensor has no control function is only fitted to monitor the performance of the upstream sensor and cat.
In closed loop running the upstream and down stream sensor should give very different readings, the upstream sensor should be continuously changing
high to low and back, the downstream sensor should give more or less the same reading continuously. The ECU compares the reading of the upstream and
downstream sensors if they are the same too often it flags a fault code indicating either a catalyst fault or a lambda fault.
[Edited on 30/10/08 by britishtrident]
prawnabie
| posted on 30/10/08 at 12:57 PM |
Both sensors are the same part number and therefore have the same size leads.
I can get you a genuine renault one, the cost price is 87.40 + vat + a couple of quid postage.
Retail is 109.25 + vat.
As regards to the megane, Its more than likely going to be the UPC that you have dried out. It is basically a power distribution unit with a main bus
bar fed by the battery. Water is the death of these units - Renault have turned the unit upside down on the later models to try and combat the
problem!
I can do you one for cost get it programmed at a discounted rate, but I am based in the midlands so you would need to get the car here!
davie h
| posted on 30/10/08 at 01:08 PM |
How much are we talking for this upc thing is it into the hundreds
Davie
prawnabie
| posted on 30/10/08 at 02:17 PM |
about £130 plus vat for upc - retails at 160 + vat
