Author: Subject: Checking auto box oil
piddy
posted on 1/11/08 at 03:58 PM Reply With Quote
Hi.
How do you check the oil level on a auto gearbox fitted to a 2005 1.2 Vauxhall Corsa?
mr henderson
posted on 1/11/08 at 04:42 PM Reply With Quote
Usually you need to stand the car on level ground, starft the car and let it warm up thoroughly, then move the gear lever through all positions 3 times, then check the dipstick with the engine running in 'park'. Thats how you do it on a RollsRoyce, anyway, may well be the same for a Vauxhall
John
jollygreengiant
posted on 1/11/08 at 05:32 PM Reply With Quote
A lot of modern vauxhalls do not have a dip stick. You might need to check the level through the filler hole on the gearbox casings if the is the case.
TPG
posted on 1/11/08 at 06:27 PM Reply With Quote
As per above,Most modern boxes are "sealed for life" but do have a checking process that involves getting underneath.Which are quite critical on 'temp etc etc,Have a google at it.
[Edited on 1/11/08 by TPG]
..Which was nice..
posted on 1/11/08 at 07:45 PM Reply With Quote
Most "sealed for life" gearboxes aren't!!! But it's true they generally have to be assesed via the filling hole.....
posted on 1/11/08 at 08:33 PM Reply With Quote
Most thses days are checked via a level plug -- transmision fully warmed up engine running.
Three important things
(1) Check temperature of transmision. with a digital probe.
(2) Car must be truly level.
(3) MUST use exactly the correct fluid --
All especially vital if tanny is a CVT type --- unlike the tough old autos trannies of the 1960's modern ones are highly sensitive beasts.
[Edited on 1/11/08 by britishtrident]
