Author: Subject: P4 Rover, whats one like?
Mr Whippy
posted on 3/11/08 at 10:52 AM Reply With Quote
What are they like? There’s one sitting along side a house nearby for the last 2 years at least and although never been worked on and definitely an abandoned project car, looks in extremely sound condition. Even if the engine was knackered or missing I have a v6 and a type 9 ready to bolt in. I’ve read that they are remarkably robust cars. Anyone got or had one? Does it have a column or stick shift?
looks very like this one -
posted on 3/11/08 at 11:08 AM Reply With Quote
My great grandad had one
They had a pre select column change with a fluid flywheel, probably similar to some of the buses you've driven.
mookaloid
posted on 3/11/08 at 11:23 AM Reply With Quote
I had a ride in one once - it had a knob on the dashboard which you had to wind to put it into 'freewheel mode' for down hills to save fuel.
You then had to wind the knob back in to re-engage drive!
It would be a fun car to have but it would be heavy and would need some attention to the suspension if it was ever going to handle
Mr Whippy
posted on 3/11/08 at 11:28 AM Reply With Quote
hmm sounds a right dodgy system that, think I'd rather use my own engine and gear box. Quick look on the web shows a simple landrover type chassis well suited to an engine conversion. Think I'll go up tonight and speak to the guy. Fancy doing a lowered custom cruser job on it in metalic purple and some nice alloys and a set of sidepipes
this red one looks ok but needs to be lower -
[Edited on 3/11/08 by Mr Whippy]
splitrivet
posted on 3/11/08 at 11:51 AM Reply With Quote
My dad used to have one, just about made it from one filling station to the next.
Bob
Mr Whippy
posted on 3/11/08 at 11:52 AM Reply With Quote
Bob
I'd run it on LPG...
x_flow57
posted on 3/11/08 at 12:08 PM Reply With Quote
I've had a few.
They didn't call them an Aunty Rover for nothing. Heavy, slow, cumbersome & by hell do they rust!
Mr Whippy
posted on 3/11/08 at 12:12 PM Reply With Quote
anywhere in particular?
x_flow57
posted on 3/11/08 at 12:20 PM Reply With Quote
Just about everywhere it's a classic british car, chassis, sills, floors etc etc.
MikeR
posted on 3/11/08 at 12:21 PM Reply With Quote
Bloke in the office has two (he's been making one into a runner for years but never bothers working on it).
Its de-dion rear, handles bumps well and cruises would be how he'd describe it. Has things like intermittent wipe - based on using a vacuum!
Mr Whippy
posted on 3/11/08 at 12:52 PM Reply With Quote
hmm true, but this one is a bit odd, it's amazingly straight looking and only shows some surface rust on one half of a bumper. Worth a further look me thinks.
cheers.
jimmyjoebob
posted on 3/11/08 at 06:49 PM Reply With Quote
My mate has had several of these. First thing he would do when buying them is to strip the kingpins out and clean out all the grease. The steering is transformed when they are oiled as this is what they were designed for!
Great cars for smoking around in!
If at first you don't succeed, hide all evidence you ever tried!
posted on 3/11/08 at 07:37 PM Reply With Quote
With the exception of the Land-Rover powered Rover 80 the engine was an over head inlet side exhaust (IOE) with an alloy head. The entry model 60 was a 4 cylinder all the rest (apart from the 80) were straight 6.
Gear change was via remote on the bottom of the dashboard.
The top model the 110 produced a claimed 123 bhp which made it faster than the contemporary 2.4 Jag.
The handling wasn't that bad either most of the chassis and suspension components were re-used in the 3 Litre P5 and the 3.5 V8 P5B. Steering was lighter and more precise than the directly competing Humber Hawk & Superb Snipe.
The car in the picture looks like one of the lower priced models perhaps an 80 or 75.
The IOE engine was produced well in to the late 1970s for the original 1 ton model Land-Rover and 109 Station wagon so spares are still available.
[Edited on 3/11/08 by britishtrident]
posted on 3/11/08 at 07:38 PM Reply With Quote
My dad had a 1953 Rover 100 (P4), and I drove it for a while.
Expect 13 - 15 mpg for a 100 model (2.6 litre straight 6, single BIG SU carb). Conventional 4-speed gearbox, with an overdrive switch on the column (4th gear only). Heavy, reasonable to drive, comfortable.
The chassis is a twin rail ladder with HUGE members. The body is mostly skinned in aluminium, with steel wings - so rust between panels is a risk.
posted on 3/11/08 at 07:45 PM Reply With Quote
Live rear axle --- leaf springs very much the same as a a Series 1 or Series 2 Landy.
posted on 3/11/08 at 07:48 PM Reply With Quote
Think you might be confusing it with a Daimler or Lanchester which used the Wilson Pre-selector box -- Rover used a conventional transmissions.
posted on 3/11/08 at 07:53 PM Reply With Quote
Originally my dad had a Rover 90 - that had a 4-cylinder engine, conventional 4-speed box and a strange free-wheel device operated by a large knob on the dash (maybe what he was thinking about). It wasn't a pre-select box, but the free-wheel meant that you could change gear without using the clutch - but it was a slow change, so using the clutch was quicker.
It was quite scary, as all I'd driven before was an old mini - a 2-ton car with no engine braking was an 'interesting' experience!
posted on 3/11/08 at 07:57 PM Reply With Quote
This is a true British classic a quality car don't molest it --- really not something to ar*e with crappy Ford engine & box
