pedal box
troid - 10/7/05 at 03:22 PM
hi all
has anyone got any pictures of their pedal box assy using mk2 escort pedal or has anyone got any ideas to make this job alot easier
thanks
Avoneer - 10/7/05 at 04:01 PM
I found MK's is probably the best/easiest/simplist and best value for money as it uses the Sierra master cylinder.
Have a search for "best pedal box".
Hope that helps,
Pat...
clbarclay - 10/7/05 at 04:33 PM
MK pedal box can also be used with an escort MC. As for simplest probably yes, but as for easiest, I doubt it because the kit comes in 4 components each having to be welded to the chassis seperatly. Compare this to may pedal box assemblys that come as one complete unit that can be bolted or welded to the chassis.
troid - 10/7/05 at 05:54 PM
I dont want to sound stupid but is may a name of a manufactoer as im using escort master cylinder?
Avoneer - 10/7/05 at 06:19 PM
Do you mean MK?
If so, yes it is a manafacturer.
Pat...
troid - 10/7/05 at 08:06 PM
once again thanks all
gonna go for the mk one that bolts to the floor looks spot one
Steve Hnz - 14/7/05 at 11:36 AM
I'm picking that "may" was sposed to read "many" in which case it would make more sense in this context.I Think! Cheers, Steve.
