Hi,
Doin some research into ZX12 motors and need some physical dimensions.
I need to know the max width of one (clutch case to generator case - across the crank)?
And overall height ?
Just need to compare them against ZX9's R1's etc for a front engine RWD mini project i'm about to undertake.
a bit rough but as close as i can measure it.
clutch case to generator case ........ 21 inchs
bottom of sump to throttle body......26 inchs (not including filter)
hope this helps
Dan
sorry thats for zx12r,
cant help with R1 or zx9
Thanks Dano,
Somebody will be along shortly with the missing ones hopefully.
I'm just gathering info at the mo for a RWD front engine Mini project.
There's quite a few R1's and Zx9's around but not many ZX12's (I only found one sofar, but he seems to just about fit!!!)
Ta
