Hi, has anyone got a picture of a tidy engine bay with an r1 lump fitted? I need some motivation before i end up dumping it all in the scuttle. Any
advice on achieving a tidy engine bay - wiring wise would be greatly appreciated.
Adam
I am facing the same problem myself but as far as I can see it is impossible to do it properly without extending the bike loom.
Check stuart_g's photo archive as his engine bay is immaculate (not jealous - honest)
use plenty of spiral rap
Not an R1 but at least it's a BEC!
Here's my old bus:
Also a couple of links to larger pics:
Bay 1
Bay 2
HTH
Lyn
Not R1 - or even BEC IIRC but check out Fozzie's archive for super OCD esque tidy engine bay - squeaky!!!!
Here's mine.
I tried to get all the cables in the engine bay into a small loom then put it into convoluted tube and then cable tied it to the under side of chassis
tubes.
I did have to extend and replace parts of the R1 loom to get them into the right areas out of sight.
[Edited on 16/7/08 by stuart_g]
have a look in my archive under 5vy motor
[Edited on 16/7/08 by r1 locost]
Just the sort of examples i was looking for, cheers guys. I now have quite a high standard to follow and it looks like i'l be getting the wire stripper and crimps out again Doh!
mine looks like a bomb blast in a wire factory.
