Following on from the thread on 12mm 1/2" bolts etc. I am going to swop my M12 bolts on my current build. Does anyone know a supplier of
1/2" bolts that are 9 1/2" long? All the usual suppliers only go up to 6".
When i get stuck for things i try bradford bolt and nut.
Ps this thread looks cool on the front page, with no /'s. 12" bolts 912" long
Got to ask, what do you want bolts that long for?
Yep i may be on the hunt to!
If i find someone ill tell you.
Threaded Bar? with welded nut on one end....
Or give BAPP for bolts a call in donny
http://www.bapp.co.uk/
They got me all the bolts i needed from a list including ALL for kit car.
ALL HT
50 m12 4"
50 m10 4"
50 m10 6"
100 m8 6"
100 m8 4"
including the nuts /nyloc and not. and the track rod bolts and so on.
for about £50.00
[Edited on 25/1/12 by jossey]
Try orbital fasteners website longest M12 they do is 240mm
[Edited on 25/1/12 by Talon Motorsport]
NFHTB420 *1/2 UNF X 10 HT BOLTS* from Lincolshire fastenings company ltd
They are not 9.5" though
Also what is the desired thread UNC or UNF. I would gues UNF (Fine) so it can take the tensile strength easily.
Go to www.classicnutsandbolts.com they have them in stock in high tensile, I just bought some from them last week and they did mail order.
glad I looked in here now, I also need them
my rear end all 1/2" holes and spacers etc, but the bolt kit was M12, fekin eejits
and NO NO NO to using threaded bar
Thanks Brooksey
Just ordered mine. Full set of bolts, washers and nylocs for the car delivered for just over £41 inc the dreaded. I didn't think that was too bad
as the 91/2 bolts are over £6 each and the courier £10.
