Anyone fancy a winter project?
Space needed.
Half built MK Indy tucked away in the back of my nice dry garage, not touched for seven or eight years. this was going to be a track only car but
would be a good basis for a road car if desired. no photos as there is too much stuff in the way to get it out but if someone is seriously interested
they can come and have a look.
Not looking for a lot of money - I know things are only worth what someone will pay so come and have a look and make me an offer. Getting it away is
more important than the price.
Description from Memory in no particular order:
Rolling chassis with full welded cage.
2 sets of alloy wheels
all new protech shocks, suspension and brakes - the discs (all round) will have a bit of surface rust I expect but the brake fluid is DOT5 silicone
fluid which is non hygroscopic so the brakes should be fine.
honda blackbird engine fitted with a shallow sump. yes I know. It comes with an accusump which I believe would solve the oil starvation issue. or
chuck it away and stick something else in. propshaft connected up to sierra back axle. Not sure about ratio but also have a spare diff and drive
shaft.
The steering is fitted with MK Modded narrow rack and a nice small steering wheel.
other controls: clutch is cable converted, hand brake works, steering column gear change, no throttle cable fitted.
Fibre glass seats present - need fitting
Side panels, wheel arches, scuttle and nose cone in blue need fitting no rear panel.
aluminium fuel tank, radiator. need plumbing in.
There is no wiring, no ignition system, no lights etc
Various exhaust parts including original manifold and choice of silencers
Located near Bedale North Yorkshire. message me if interested.
Mark
U2U sent
I can’t believe this sale has not been snapped up
Jacko
Yeah i'm with you, LB and ebay both break my heart not being able to find the space or money to take in all these projects...
Good luck with the sale!
U2U sent Mark
Sale now agreed. thank you all for your interest
